| Engine torque specs | |
| Topic Started: Dec 25 2008, 08:34 AM (1,061 Views) | |
| Johnny Mullet | Dec 25 2008, 08:34 AM Post #1 |
"Mullet of Ox"
Torque Spec Chart............................................ Ft lbs (unless indicated) Camshaft bearing cap bolts Three cylinder...................................................................96 in-lbs 1998+ four cylinder...........................................................96 in lbs Camshaft sprocket bolt Three cylinder....................................................................44 Four cylinder......................................................................43 Cylinder head bolts Sprint................................................................................48 Metro 1998 and older.......................................................54 Metro 1999+ 3 cylinder.....................................................54 Metro 1999+ 4 cylinder.....................................................49 Crankshaft pulley bolt 1994 and older ................................................................96 in-lbs 1995+ 3 cylinder..............................................................144 in-lbs 1995-1998 4 cylinder........................................................97 in-lbs 1999+ 4 cylinder..............................................................144 in-lbs Crankshaft sprocket bolt 1994 and older Sprint.......................................................52 1994 and older Metro.......................................................81 1995-1996 3 cylinder........................................................81 1997+ 3 cylinder...............................................................96 1995-1996 4 cylinder........................................................79 1997+ 4 cylinder...............................................................96 Distributor gear case 3 cylinder..........................................................................96 in-lbs 4 cylinder..........................................................................96 in-lbs Exhaust manifold 3 cylinder..........................................................................17 4 cylinder..........................................................................17 Intake manifold 3 cylinder..........................................................................17 4 cylinder..........................................................................17 Flywheel bolts 1994 and older.................................................................45 1995+ 3 cylinder...............................................................55 1995-1996 4 cylinder........................................................45 1997+ 4 cylinder...............................................................57 Oiling system Pickup tube bolt................................................................97 in-lbs Bracket bolt.......................................................................97 in-lbs Pump to block...................................................................97 in-lbs Oil pan..............................................................................97 in-lbs Rear main seal retainer.....................................................99 in-lbs Valve Train Rocker arm adjust............................................................156 in-lbs Rocker arm retainer..........................................................97 in-lbs Timing belt tensioner bolt ................................................20 Timing belt tensioner nut..................................................97 in-lbs Valve cover 1994 and older .............................................96 in-lbs Valve cover 1995+............................................................44 in-lbs Valve cover 1999+ 4 cyl....................................................97 in-lbs |
4:00 AM Mar 14
