Belt squeal?
Topic Started: Jan 8 2009, 09:36 PM (3,084 Views)
BiggJames
Well when i start my metro the belt squeals like hell. Then it will go aways after about 30 seconds. then if i hit the brakes it squeals again. and when i turn the headlights or any accessories on the belt squeals and the headlights and dash lights dim for about 30 seconds? the altenator bad?
First the basics.............
Check battery terminals for corrosion or looseness.
Load test battery and replace if bad.
Remove that alternator main wire, clean connection, reinstall.
Test alternator with voltmeter.
Finally, get rid of that old belt and replace it with a Goodyear Gatorback alternator belt. Available at AutoZone or Check here........
http://www.goodyearep.com/locatorrp.aspx
Rooy
Also check the belt tension. They need to be fairly tight to not squeal in my experience. Manual says .024"-.031" @ 22 lbs pressure, tested in the middle of the front belt run.
z34-5speed
Formerly "Tech Certified"
I had a similar problem with mine. I just had to have a friend put all his weight onto the alt while i tightened it. It never squeaked after that.
gangsta_money23
either tighten or replace the belt. same thing happened is my gfs car a while back, all it needed was a good tightening
r12methane
R12METHANE
Put some coolant dye in the radiator and check waterpump to see if it is starting to leak.The You can check it by buying a penlite with a blue lens..It may be leaking out the pee hole on the bottom or from the gasket..Loosen the timing cover and check in there too..Also it may be getting oil on it from the crank,cam seal or the oil pan leaking ...
PushnFords
I have the squeel at startup but not the other times. I just bought a Gatorback belt on eBay this week for under $8 shipped. The seller had a few more left. Look up the part number somewhere like www.autozone.com and then search eBay Motors for that part number.
Derek
Ryan
Ryan
Mine did the same thing last winter (had the original belt too). I replaced it with that cheap AutoZone belt. It worked until the next morning. Tightend it down further and it never came back. Did the same thing with the Goodyear belt I have this winter. Cured. I heard these models are notorious for this problem.
Ryan
Ryan
PushnFords
Jan 9 2009, 08:25 PM
Derek
Awesome. That's about what I paid for mine from Parts Plus online. Let me know, however, how that belt works out for you. The guy at the local import shop dislikes the criss-cross design. He recommended a Gates belt from NAPA. So far, I'm keeping the Gatorback.
PushnFords
Ryan
Jan 10 2009, 03:10 PM
I'll let you know. I didn't really want to tighten my current belt anymore than it is...just puts a lot of strain on the water pump and alternator. I'm running a Gatorback on my Ranger and have put them on a few other vehicles and always had great luck with them.
Derek
