1994 metro rebuild ?'s
Topic Started: Feb 1 2009, 09:29 PM (1,329 Views)
BiggJames
I am planning to rebuild my 94 in the next few months and was wondering if someone could give me a list of everything you need to do one so i can get prices. I am planning on getting the 3tech head also. Me and my good friend/auto tech teacher are going to do it im excited. :rocker
Well, if you are getting the complete head with your choice of cam and gears, then do you want to rebuild the bottom end? The basic needs for this job are...............
Head gasket kit
Timing Belt
Water Pump
Piston rings
Rod bearings (if needed)
chads4dr
Feb 1 2009, 10:35 PM
Head gasket kit
Timing Belt
Water Pump
Piston rings
wow! thats all you need for the bottom end???? Im itching to rebuild mine someday Ill have to keep this in mind!
metromad
I would also add an oil pump to that, or at least a front crank oil seal. Its the same seal as the camshaft seal (timing gear side). You will probably get one in the gasket kit (Fel-Pro provides one in their kit anyway) so just order another camshaft seal when you order the gasket kit.
chads4dr
metromad
Feb 2 2009, 09:48 AM
cool....... thanks
BiggJames
thanks guys im excited about this rebuild :drivin
billy508
billy508
:thumb You guys are pretty smart by planning ahead. Dont try to rush the job when you start. You can get by with it if you are a pro like like Mr Mullet and some of the others. Be sure to remember the check valve. Good luck :drivin :drivin Looking forward to your progress. Its quite a feeling to know that you take a engine apart and put it back together as good as new or better.
hotdiesel80
94 rebuilt head with cam installed, send back your used head -200 $, installed one on my 94 getting 52 mpg ,shift set at 2700 rpms ,its great to get your 50 mpg car running again ! don't forget the oil valve ,be a no smoker
