Charging System Not Working
Topic Started: Feb 9 2009, 05:25 PM (5,266 Views)
Feb 17 2015, 04:41 AM
Post #16
- 13,848
- Group:
- Tech Certified
- Member
- #471
- Feb 13, 2009
- Location
- College Park, MD
- Year/Make/Model
- 1991 Pontiac Firefly Turbo 2010 Kizashi GTS
Dude, this discussion is from six years ago. You really should start a fresh subject in the electrical section.
No, the ECM has nothing to do with charging. In fact, no matter what your problem is with your Metro, it's not the ECM, they're the most reliable part of the entire car.
There's not much to the charging system on a Metro, battery, alternator, two big cables, and the connections underneath the fusebox.
Feb 17 2015, 09:26 AM
Post #17
- 5,898
- Group:
- Tech Certified
- Member
- #1,094
- Aug 12, 2009
- Location
- Mechanicsville, VA
- Year/Make/Model
- Metroless (through no fault of his own) 1989 (gone) 1996 hatchback (gone) 1992 Vert (gone)
- Hacksaw
- Feb 10 2009, 06:27 PM
The brand new "World Class" alternator that the previous owner installed was the problem. He told me he had it tested, but obviously they didn't know what they were doing. Since "275" is out of commission with a burnt valve for now, I robbed the Bosch alternator and Gatorback belt from it and put it on "400"...problem solved. I have the receipt for the new "World Class" alternator so I'll exchange it for another and put it on "275" when I fix the valve issue down the road.
Earlier today, I tinkered around with adding grounds and actually replaced the negative battery cable with a spare I had as well. All that for nothing. I've had the same problem with "tested" stuff. It usually turns out that the test was done by some less skillful individual at the big box auto stores.
For instance I took in a battery for a core told them what I wanted and the guy insisted on "testing" it, I knew the battery was wimpy to say the least, the test showed 265amps, the "book" said the vehicle would start with 260 amps and the tester proclaimed it good and tried to send me on my way convinced he had saved me from buying an "expensive" battery. I said no go, that battery is 9 years old, it just spent the last hour driving here in a warm car, it's 70 degrees in here where you are running your test which gave results barely over the minimum required, what do you think is going to happen when its 0 degrees? All I got was a blank stare. Purchased the battery I made the trip for and went on my way.
Congrats on solving your issue!
Feb 17 2015, 07:42 PM
Post #18
- 7,692
- Group:
- Moderator
- Member
- #12,381
- Feb 19, 2013
- Location
- Longview WA
- Year/Make/Model
- 95 Geo Metro 3/5 95 Geo Metro 4/5 92 Metro Vert 3/5
- idmetro
- Feb 17 2015, 09:26 AM
- Hacksaw
I've had the same problem with "tested" stuff. It usually turns out that the test was done by some less skillful individual at the big box auto stores. For instance I took in a battery for a core told them what I wanted and the guy insisted on "testing" it, I knew the battery was wimpy to say the least, the test showed 265amps, the "book" said the vehicle would start with 260 amps and the tester proclaimed it good and tried to send me on my way convinced he had saved me from buying an "expensive" battery. I said no go, that battery is 9 years old, it just spent the last hour driving here in a warm car, it's 70 degrees in here where you are running your test which gave results barely over the minimum required, what do you think is going to happen when its 0 degrees? All I got was a blank stare. Purchased the battery I made the trip for and went on my way. Congrats on solving your issue! 6 years ago...
Hanuman
Feb 17 2015, 09:11 PM
Post #19
- 3,792
- Group:
- Tech Certified
- Member
- #11,619
- Dec 2, 2012
- Location
- wasilla, Alaska
- Year/Make/Model
- 1997 3/5. 265k 4.12 trans. Xfi cam @ 16° advance, ignition timing @ 21° advance. mpg 61 hwy
- Metromightymouse
- Feb 17 2015, 07:42 PM
- idmetro
- Hacksaw
I've had the same problem with "tested" stuff. It usually turns out that the test was done by some less skillful individual at the big box auto stores. For instance I took in a battery for a core told them what I wanted and the guy insisted on "testing" it, I knew the battery was wimpy to say the least, the test showed 265amps, the "book" said the vehicle would start with 260 amps and the tester proclaimed it good and tried to send me on my way convinced he had saved me from buying an "expensive" battery. I said no go, that battery is 9 years old, it just spent the last hour driving here in a warm car, it's 70 degrees in here where you are running your test which gave results barely over the minimum required, what do you think is going to happen when its 0 degrees? All I got was a blank stare. Purchased the battery I made the trip for and went on my way. Congrats on solving your issue! 6 years ago... he still solved it, did he not?
Feb 18 2015, 06:24 AM
Post #20
- 7,692
- Group:
- Moderator
- Member
- #12,381
- Feb 19, 2013
- Location
- Longview WA
- Year/Make/Model
- Hanuman
- Feb 17 2015, 09:11 PM
- Metromightymouse
- idmetro
- Hacksaw
he still solved it, did he not? True, of course he hasn't been on since August 2014 so not sure he's going to receive his well earned congratulations.
Wirewilly
Sep 2 2015, 03:35 PM
Post #21
- Group:
- Members
- Member
- #20,930
- Sep 2, 2015
- Location
- Melbourne Florida
- Year/Make/Model
- 1997 Geo Metro 1.0 3dr
- MichaelSAlford
- Feb 16 2015, 02:16 PM
I have the exact same problem, although mine is also intermittent! I have already done EVERYTHING listed here, plus put my hands on,(as far as I can tell) every inch of every wire of the charging system, but to no avail. Does the ECM have anything to do with the charging system? It's included in the wiring diagram, but it's purpose seems murky. I got the problem with my 1997 Metro 1.0 5sp, basically I don't think any signal is coming through the I G line telling the Brand new alternator to turn on the 14 plus volts. Got a diagram , I see there should be a ignition switch on the steering column just in front of the lock & Key that should have a rod that slides down to activate the real electrical switch. Caution I've tried to find this part for my year model no dice yet. I know you said you've checked everything for a short, Have you taken the plastic off the column to look there for a short
| 1 user reading this topic (1 Guest and 0 Anonymous)
