alternator bearing replacement
Topic Started: Jul 17 2009, 10:23 AM (1,559 Views)
red_fx4
hey guys i just got my 97 i put on a new belt for the waterpump and alternator, put it in started the car and the belt started smoking, its the alternator pulley bearing, where do you guys find the replacement bearing for it? not the 40$ one from napa but the cheaper one...can i find it at a mills fleetfarm or a tractor dealership?
http://geometroforum.com/topic/1170267/
red_fx4
im going to dig a lil deeper on this subject for you guys, im going to pull out my calipers do the I.D and O.D of this bearing and goto mills fleet farm or hardware store and see if they have the bearing needed to fix this issue, who knows it could be as simple as a standard bearing! usually go for $5.00! ill do some diggin
PushnFords
Another thing you might check is bearings in pulleys as well as throwout bearings at the auto parts store. Most pulleys use standard bearings anymore. I've done this mostly with idlers and tensioners but it is amazing how often you can buy the cheapest pulley or a $5 throwout bearing and fix a pulley that would normally cost $30-50 to replace.
pancakeron
Junker's post (with the video) noted the bearing was a "model 6303"...
a quick google search turned up this site/source for bearings...
well worth checking out...note: the price........$4.95 !
Looks like they supply bearings by size and/or application.
----->>Clik Here<, or go to: http://www.vxb.com/, for more info.
-------> Posted Image
keep on roll' n...
Edited by pancakeron, Jul 24 2009, 04:24 AM.
JellyBeanDriver
Anyone know what the dimensions or pn is for the rear bearing on the Mitsubishi alternator?
JellyBeanDriver
How about ABEC ratings?
I see 3rd party (cheap) bearings are ABEC 3 rated (motor duty).
Is this sufficient or should I spring for a higher rated front bearing?
EDIT:
I think the bearing PN 6303 is wrong.
Looking up #'s in GM Parts Giant I got suzuki pn 31582-60A21 which is a 15x47x14 bearing.
The 6303 is 17x47x14
Which one is right for the Mitsubishi alternator?
Edited by JellyBeanDriver, Jun 22 2010, 12:52 AM.
