132whp@6250 and 120ftlbs@5000 on 19.6psi; a little disappointed
Topic Started: Aug 23 2009, 01:03 PM (825 Views)
Dallas
I knew everything was conservative as it is, ive blown up enough of these that im no longer pushing them to the edge with timing.
it needs more timing for sure, we have no ping even WITHOUT the meth currently, and the meth was just a failsafe for now. It is also not running the full 23psi on the dyno, nor is the fueling anywhere where it needs to be (mid 10 afr passed 6000rpm for some reason)
I didnt get a chance to tune on the dyno this time, because this was just the local meet they held at the dyno for some free pulls. so I got it over with though, I can see the powerband now, so I know where to make adjustments and go back.
this was run #3 I did, each one I added one degree (only) of timing, and I went from peak tq of 115 yo 120 and peak hp from 126 to 132, with only TWO degrees of timing. and it bumped up the whole map. so knowing that, I have some tuning to do. but I left there with a free 6hp lol.
http://www.youtube.com/watch?v=dy8gP63mKjk
next time I go back, itll make way more. but still, these things dyno less than 45whp stock...
Sweet! :thumb
Three times the factory horsepower ^o) and I like the two tone paint scheme. B-)
What are you total goals?
z34-5speed
Formerly "Tech Certified"
Thats a little more than double what it would make factory.
Dallas
Aug 23 2009, 09:11 PM
180-200 motor hp. so I guess 160whp should be realistic. I talked with dyno guy and I'm gonna work something out. stay tuned
FyreDaug
Aug 23 2009, 11:31 PM
stay tuned...it's ironic
Dallas
turns out it has like 4 different boost leaks, including a cracked intercooler. thus not max boost and low power :(
