SpeedTracer free AE tagalong program; datalogging software for the laptop
Topic Started: Sep 25 2009, 11:26 PM (1,036 Views)
mwebb
FOG
right click on the image , from the dropdown select view image to enlarge the image
speedtracer is included with Autoenginuity , i have had Autoenginuity for years and never used speedtracer until tonight
i used speedtracer to calculate fuel mileage in real time , and per the current trip . driving on local roads then on the interstate acroos the hudson river to the nearest shell station .
i had to configure the software to the car and ambient pressure and temperature as well .
speedtracer saves the data in a csv or xml file for playback or fiddleing with later or the graph can be saved or you can just press printscreen and save the file in a graphics program
or mix and match with AES annowave as i have done here
i am going to be using it to test changes as i make them ... so i don't not have to wait for a whole tank of fuel to be used to figure out that i have screwed something up
speedtracer has tabs to graph and log various things as seen in the headers of the screen caps
while it may not be 100% accurate AE software is consistant and it will provide a relative value that can be used to judge modifications for their value of improvement or degradation of .... what you are hoping to improve with your modifications
kinda like what people are doing with scangauge 2 but a bit more advanced
unfortunately the MPG graphing and datalogging peaks at 60 mpg ,
which is not not high enough for Geo Metro users ...
i have requested a way to increase that value , if one currently exists ...
Edited by mwebb, Sep 25 2009, 11:35 PM.
mwebb
unfortunately the MPG graphing and data logging peaks at 60 mpg ,
which is not not high enough for Geo Metro users ... i have requested a way to increase that value , if one currently exists ...
I want to see the results of this test! They can't believe that such sophisticated users of their software, like yourself mwebb, can't get better than 60 mpg! No, wait, they could. :smackface :whistle
Either way, it looks like route 52 HJ through Fishkill is the way to go, eh. :thumb
No scangauge, no OBDII or Autoenginuity... I'm going out for a side of ribs with The Wife and my best friends Barney and Betty. :popcorn
mwebb
FOG
typically friday night is date night
but my wife has the flu or something she probably picked up in the hospital last week when we were there for the birth of grandchild #6 .
so i was out driving around with the laptop in the car , with my right boot off and in the back seat so i did not keep knocking the AE generic connector out of the OBD2 DataLinkCconnector which is located right above the throttle pedal
Congratulations on grandchild #6! :hb
I hope your wife gets better soon.
Bootless, that's good. :lol Err, ah, Barney and Betty's last name is Rubble. :shake
mwebb
FOG
right click on image , from the drop down , select view image to expand the image
it looks like i get about 1.5 mpg improvement just by removing the air filter snorkel at 37f
only 2 passes in the same direction , with and without , should be more testing to confirm .
that was just done tonight 30 minutes ago
with the right boot off so i don't knock off the connector from the DLC
