| Bogs down at 45mph; Running bad | |
| Topic Started: Oct 27 2009, 05:08 PM (120 Views) | |
| dept411 | Oct 27 2009, 05:08 PM Post #1 |
Metro on the brain
My geo is bogging down at around 45mph. Anyone have any ideas what it could be? |
| Johnny Mullet | Oct 27 2009, 07:25 PM Post #2 |
"Mullet of Ox"
If your car is low on power, there is one important test to do. Rent or borrow a compression tester and test all cylinders. Report back with those readings and we will go from there before you start throwing parts at it. |
| mwebb | Oct 27 2009, 09:42 PM Post #3 |
yes , i have lots of ideas . but no silver bullets to slay your vampire . how about a little history ? some test results ? something to work with ? yes compression testing is a good place to begin |
| dept411 | Oct 27 2009, 10:18 PM Post #4 |
Metro on the brain
Ok I will try and find a tester and to get some readings. Then check back. Thanks
Edited by dept411, Oct 27 2009, 10:18 PM.
| Cobb | Oct 28 2009, 09:17 AM Post #5 |
So, does it power back up past 45 or 55? Mines use to do that, I sometimes had to use 4th gear to maintain 55 on slight grades. I got a temp fix by getting the 3tech 10 degree cam gear, but I need a rebuild of my engine. |
| dept411 | Nov 7 2009, 05:11 PM Post #6 |
Metro on the brain
Sorry guys I've been gone for awhile on my job and haven't had a chance to look at it much. The fortunate thing is my dad filled the car up with 98 octane and drove it while I was gone. So far its not been doing ok. I took a compression test today any way and came up with 120-120-135. Thanks. |
| Bad Bent | Nov 7 2009, 09:55 PM Post #7 |
Not good as you may already know. Did you follow the Ryan guide: Compression test.A Seafoam treatment wouldn't hurt. |
| Johnny Mullet | Nov 7 2009, 09:58 PM Post #8 |
"Mullet of Ox"
Those numbers are below the factory minimum of 156 PSI. It will run for awhile with low numbers, but not very well and eventually will need a rebuild. |
4:01 AM Mar 14
