| Metro Trans Swap - Need Advise; 1994 Swift 5sp | |
| Tweet Topic Started: Nov 27 2009, 09:02 AM (3,101 Views) | |
| Dgeo | Dec 3 2009, 06:16 AM Post #31 |
I agree about the engine. I'm doing the cam swap first to move the torque lower in the rpm range. In addition, I'm putting a rebuilt cylinder head in at the same time. |
| Murf 59 | Dec 5 2009, 02:52 PM Post #32 |
Also, I would like to add. If you are changing speed gears (IE) first through fifth. If you change out say one of the gears in 4th. Change out both gears. They are a set. What happens to one, happens to the other, except backwards. If the one gear is worn, and you put a good gear against it. It will wear to the bad one. And most likely make noise. Sorry I have not been around more on this thread. If you have standard trans Q's, PM me. I can only be here on and off now. So it may take me a few days to get back to you. But I will get back. |
| geosedan | Dec 28 2009, 07:51 PM Post #33 |
I have a 1996 metro lsi sedan 4 cylinder. From what I understand on this thread I must have the 3.52 final drive tranny and there is no way to lower the rpm's from what I now have other than getting bigger rims and tires correct? |
| Murf 59 | Dec 29 2009, 12:41 AM Post #34 |
You don't have to get bigger rims, just taller tires. And narrow is better. Less friction on the road. If you pull the speedo cable where it goes into the trans. You should be able to count the teeth on the ring gear. I think the 3.52s, use 74 teeth. I don't have my cheat sheet here. |
| Dallas | Dec 29 2009, 12:47 AM Post #35 |
theres also the possibility it was swapped at one point too. you never know with these cars |
2:05 PM Jul 11
