1.0L 3 Cyl. - Interference Engine?
Topic Started: Dec 30 2009, 11:05 PM (7,281 Views)
Dgeo
I'm rebuilding a '98 Metro 1L engine. I have the cam out being reground at Delta cams. I want to install the head, while waiting on the cam. Is this engine an interference engine? Can valve timing and piston timing be out without damaging the engine. I have heard conflicting views. I know I'll have to rotate the cam when I get it back, but want to bolt the head back on the block before then.
Dallas
non interference
Dallas
Dec 30 2009, 11:32 PM
non interference
this
LittleSilverCar
1.3L non interference?
Dgeo
Dec 30 2009, 11:33 PM
Dallas
non interference
this
Thanks........... :thumb
Dallas
LittleGreenCar
Dec 30 2009, 11:35 PM
not sure about the sohc ones, but the GT motors most definitely are
chads4dr
1.0 SOHC G10= non interference
1.3 SOHC G13A, G13BA, G13BB= non interference
1.3 DOHC G13B=bye bye valves :)
Dallas
while we are on this topic, how about the 1.6's? g16a I believe?
If you believe what's in Wikipedia; wikipedia.org/Suzuki_G_engine It only has interference info. up to G13BB, the reference is a broken link. :shake
starscream5000
The only way a G10 will an interferance motor is if you have a cam with more lift, and/or you've shaved the head and block a lot. When I say a lot I mean .050" and up. You may get by with .050" but I'm not entirely sure...
3tech
Still wouldn't be.
starscream5000
How much would it take to make it interferance? .070"?
3tech
I have run a .375" lift cam, with .100" removed from the head, and it still wasn't an interference motor. I do have a head cut in half lengthwise for measuring stuff like this. I could go back and have a look, but my guess is (from memory) that you can't make it happen.
LittleSilverCar
chad8329
Dec 31 2009, 12:21 AM
:D Learn something new everyday, way to calm my nerves
starscream5000
suprf1y
Dec 31 2009, 12:07 PM
No need. I'll never remove that much from block when it is built. I was just making sure that I was still in the green!
