no spark issue
Topic Started: Jan 20 2010, 07:02 PM (1,904 Views)
dragnfly
I have a 2000 1.0 firefly, back in '05 the spark started kicking in and out then finally quit, no one could find the problem and the chev dealer finally determained it was the computer and replace it, luckily for me under warrenty. The spark started doing the same thing in aug of '09. The spark work quit I would mess with the plug wired and the spark would come back , it did this a few times over a couple of weeks then the spark quit and would not come back. I parked the car and left it for 3 months , I decided one day to see if the battery was still good and figured I might aswell turn the engine over , well it started right up. I havent been driving it as Im worried it will die agian.
I have been told I have an electrical issue and not a computer issue. Any suggestions on which wires to start looking at , any info would be greatly appreciated,
thanks for your time
Any place the wiring passes through the firewall is a good place to check, but I would start be checking all the ground and battery connections. Welcome aboard and hopefully we get this resolved.
I suppose the dealer replaced the ECU and it was fine for 4 years? The ECU rarely goes bad in these cars. Maybe something to do with the wiring to the ECU?
Did you replace the plug wire that you would mess with?
Might move some other wires and see if anything changes. :dunno
mwebb
FOG
http://geometroforum.com/topic/2703156/1/#new
the ECM needs signal from CKP and CMP to know when to command spark , so that is a good place to begin
if there is no CMP or CKP signal the ECM does not know that the engine is rotating so
the ECM responds by doing nothing , which is what it is designed to do .
do you have signal to the spark module / controller ?
if yes to this , then CKP and CMP are ok
do you have signal to the injector ? if no
and no signal at the spark module then you need to test CKP and CMP
http://geometroforum.com/topic/2810401/1/#new
here is a basic way to test the injector for signal
http://geometroforum.com/topic/2680128/1/#new
and here is how to go about connecting to the circuits without damaging the insulation
time for a DVOM and a test light .
post your test results for more guidance
:smackface
Welcome to the forum, dragnfly! :coffee Tim Horton of course. :drool
Have a happy Olympics. :D
dragnfly
yes the dealer replaced the ecu and it was fine for 4 years and 55,000kms. at this moment the car is running perfect. i will have to wait for the spark to cut out agian to check the wiring . i will make sure that all connections are tight. thanks to everyone for the replies . i look forward to learning and enjoying the site.
colin
jellybean
If you go through the steps above you will find your problem however i experienced a similar condition and it was the ground wires on the intake, hard to see and easily overlooked but easy to fix
undgsx-R
Self Certified Garage Mechanic
Also it may be wise to replace the distributor cap, rotor, spark plugs, and wires.
dragnfly
My car has been running great for 6 months. When this problem first happened in 2005 I switch out each piece I could think of indiveduly to try to rule out things one at at time, ( rotor, cap, crank sensor, coil, ect) nothing made a differance so I figured each of those items were working fine. After driving everyday for 6 months hassel free the car suddenly wouldnt start yesterday, cranking over with no spark so my issue was back. I thought what is the easiest thing to start with, I removed the crank ensor and noticed it was dirty I took sandpaper and litely sanded the end till the center was clean and shiney, replaced it , turned the key and it started right up. I'm hoping this was the issue all along , time will tell.
Thanks everyone for the input love thios site , I have used the info here many times on my 4 cars.
dragnfly
that didn't last long car ran great yesterday . I left work at 2:30 am last night and the car did it agian , was cranking over for about 2 mins without showing any signs of starting . I let it sit about 30 seconds and turn the key and it started right up. This thing is making me crazy can't seem to find what is shutting off the spark so randomly
crankcase
If you could get an oscilloscope to the low side of the coil when the problem happens,
you could eliminate a number of possibilities.
Welcome back. :)
What solved the problem in January?
It being a 2000 I don't have FSM on that. Did you test it according to mwebb's procedure?
So at some point everything works but it takes two minutes of cranking and 30 seconds of waiting. Wow, that is intermittent and as mwebb points out a good place to start is the distributor. I'd also clean every ground.
mwebb
FOG
mwebb
Jan 20 2010, 11:25 PM
you will need to provide some test results .
read this
it may be way over your pay grade right now but you do have the ability to learn it and to perform the testing
do the best you can with what you have to work with
provide something in the area of test results so we can provide guidance.
my magic wand has been sent out for cleaning and the annual service so i can not fix it that way
Mwebb, are you using the Duey, Cheadum, & Howe magic wand cleaning service again? :lol
I've heard of fuel injectors acting this way just before they quit completely.
