| Vac dist vacuum pressure | |
| Tweet Topic Started: Jan 23 2010, 01:59 AM (787 Views) | |
| Murf 59 | Jan 23 2010, 01:59 AM Post #1 |
Hi guys, I finally picked up a vac dist for the Starr car. Does any one know if I need to run manifold or port vacuum? And at what pressure should I start at. Do they still sell the inline vacuum restricters? Thanks guys |
| mwebb | Jan 23 2010, 12:20 PM Post #2 |
FOG
manifold vacuum to the retard diaphragm if it has one . ported vacuum to the advance diaphragm . why ? are you using this ? |
| wikityler | Jan 23 2010, 02:32 PM Post #3 |
Some say...
Inside diaphragm to TB sensing port centre. Outside diaphragm to the gas filter on the #1 intake runner. |
| Murf 59 | Jan 24 2010, 12:00 AM Post #4 |
I am going with motor cycle carbs. One for each cly. I don't think our brain box will work. This dist does have one pushing, and one pulling. Thanks for the info. I am having to make the manifold to fit the carbs. Should be pretty radical and just under 13to1. I was hoping for a little less. I will have a better # when I get my stuff back fromt the machine shop. I am having bob weights made to balance it. So I am waiting on one machinest, so I can take it to another machinest. Makes my head hurt |
1:55 PM Jul 11
