Compatible Flywheels for non turbo G10's
Topic Started: Jan 27 2010, 04:00 PM (854 Views)
starscream5000
For searching purposes, I figured starting a new thread on this topic would help.
Will this one from a 1.3L fit?
And turbo G10's, do they use the same flywheel as the one above? If so, a turbo flywheel/clutch kit will work on mine, yes?
3tech
These are all the same, and all fit.
G13
G13 DOHC
G10 T3
They are lighter, and use a larger clutch/pressure plate assembly.
It looks like that one will fit, as long as it is what it says.
starscream5000
Thanks Mike!
Dallas
and the smaller clutches are worthless at holding power if you ever want to consider something in the future. the clutch will be the first to go, using the lighter wheel and the bigger clutch is just a good idea. you could get a flywheel from a yard for 20 bucks, since you should be machining yours anyways, its only an extra 20 bucks as im pretty sure the clutch kits are priced about the same big or small
That will work, but it's $110 once it's shipped to you. Take Dallas' advice and get one from a junkyard, any Swift or Metro four cylinder will do. Good luck finding a turbo in Kentucky, they didn't sell them in the States.
Edited by Woodie, Jan 28 2010, 06:44 AM.
3tech
Oh yes they did.
starscream5000
Heh, more like, "good luck finding a junk yard around here". They've all closed down around here. I'll dig and ask around locally if anyone knows of one that's still open around here.
