idle surge; surge
Topic Started: Jan 29 2010, 09:25 AM (699 Views)
fun4u2bwith
hello i have a 2000 metro when it starts it will warm up and start surging any idea ??
owl
Check for disconnected or cracked vacuum hoses. My 93 did that, and I found a line under the throttle body had come loose.
mwebb
FOG
yes , vacuum leak
OR
the TPS closed throttle switch is never reporting that the throttle is closed
so the idle circuit never gets activated and
you have no decel fuel cut off which will be bad for fuel economy .
AND
the EGR self test will never run
some one may have tampered with the throttle stop screw OR the throttle cable is too tight.
Welcome to the forum, fun4u2bwith! :coffee
To be a little redundant try: Engine Idle
