Check Engine Light giving a P0443 OBD code; Attempting to get my 1997 Geo Metro to pass emissions
Topic Started: Feb 2 2010, 07:32 AM (3,165 Views)
wintirwolf
I've got a 1997 Geo Metro 1.3L MFI 4 cyl (automatic transmission) that has had the check engine light pop up. I've had it scanned and the OBD code that it gives me is: P0443 - EVAP System Purge Control Valve Circuit Malfunction
Any information on what I need to correct this situation would be muchly appreciated. :ermm:
jellybean
i just googled that code, it has to do with the purge valve on the charcoal canister check for broken vacuum lines first.
mwebb
FOG
this is a circuit malfunction code
this is not a leak code
based on description provided
do not bother checking vacuum lines , even if they do leak the ECM does not care , yet , it may after the purge valve function s as designed
assuming no other DTCs - i would ask for Mode 6 test results if they are available
get to the purge valve and measure supply to it
on both pins
see the how to section for the T pin thread
when connected key on engine off both pins at the purge valve must have 12v
if you disconnect the connector , only 1 will have 12v
get this far and report your test results
if needed , i can guide you to make the purge valve work / open and
test for vacuum on the port before and after opening it
Edited by mwebb, Feb 2 2010, 12:57 PM.
Welcome to the forum, wintirwolf! :coffee
Follow mwebb's directions. :thumb He'll get you through the testing.
If you are keeping you car I'd suggest getting your own OBDII scan tool. Starting at $36 on eBay. They also throw "pending codes" when something may go wrong plus you can clear codes in case it's a false code. There are better ways to get code but this is budget.
My favorite site for understanding the codes that the Wife's Geo throws is http://www.obd-codes.com/p0443,<-- This links to your p0443 code.
Edited by Bad Bent, Feb 2 2010, 08:48 PM.
