| strange noise after rebuild | |
| Topic Started: Feb 8 2010, 07:07 PM (142 Views) | |
| crustywantabe | Feb 8 2010, 07:07 PM Post #1 |
so after my rebuild, (rings, bearnings, and valves) i started her up and it fired right away but the motor seems to have a noise coming from the belt region. when i plug the vaccum line that is behind the carb that goes to the air cleaner it seems to go away and pur like a kittin. I dont see the correlation between these two and am hope the pros can help me out. I can post a you tube video if it would help. Also were does the black plug that is a ground that is located right on the coil plug into? I cant find where it goes for the life of me. One more thing, if anyone has the clamp that hold the speedo cable in and is willing to get rid of it cheep let me know thanks eric |
| Johnny Mullet | Feb 8 2010, 07:12 PM Post #2 |
"Geo Whisperer"
A video and a pic of the hose would help a lot in this situation. |
| enginedoctorgeo | Feb 8 2010, 07:17 PM Post #3 |
That little black plug should plug in at the distributor. |
| crustywantabe | Feb 8 2010, 07:19 PM Post #4 |
i dont think it will reach, but maby im at school right now and cant check but where talking about the one that is hooked to the speedo cable right |
| crustywantabe | Feb 8 2010, 07:30 PM Post #5 |
its the hose that is located at the back of the carb and points upwards and goes in the bottom of the aircleaner. I has some type of little box or something on it. |
| starscream5000 | Feb 8 2010, 08:03 PM Post #6 |
AKA 95_G105spd
Look at my how to thread on pulling a G10, the picture your needing is in there. |
| Johnny Mullet | Feb 8 2010, 08:18 PM Post #7 |
"Geo Whisperer"
This thread has all the pics.............. http://geometroforum.com/topic/2539369/ |
| crustywantabe | Feb 8 2010, 08:22 PM Post #8 |
ahh that thing that when i plug it the noise goes away is the Idle Speed Control Solenoid Valve Silencer. Why does it change the sound of the engine? |
| crustywantabe | Feb 8 2010, 08:25 PM Post #9 |
and good call on that wire, Distributor Grounding Wire, well that throw the check engine light on |
| enginedoctorgeo | Feb 8 2010, 08:35 PM Post #10 |
The idle speed control is what most likely threw the code if you were fooling with it. |
| crustywantabe | Feb 8 2010, 08:41 PM Post #11 |
ok ill disconnect the battery tonight and plug in the distrib ground and see how see runs, since the sound seems to be coming from the belt pulley, water pump, alt area can i take the belt off and start it to possibly rule out the water pump and alt? |
| enginedoctorgeo | Feb 8 2010, 08:51 PM Post #12 |
Just dont run it too long and run it hot. Did you post a video anywhere? |
| Johnny Mullet | Feb 8 2010, 08:56 PM Post #13 |
"Geo Whisperer"
If you start the engine with no belt on, and the noise goes away, then it's the water pump or alt. |
| starscream5000 | Feb 8 2010, 09:36 PM Post #14 |
AKA 95_G105spd
Thanks jonny. It can be a real pain to copy that link on my cell. That is my main means of internet communication after work hours as I don't have internet on any of my home computers. |
| crustywantabe | Feb 8 2010, 11:30 PM Post #15 |
hahaha I went to take the belt off and bump my belt pulley and it just about fell off! I guess i forget to tighen them thanks for the help everyone |
2:01 PM Sep 3
