Stiffer valve springs - anyone have them?
Topic Started: Feb 10 2010, 12:19 AM (2,400 Views)
Dallas
suprf1y
Feb 15 2010, 05:01 PM
Keep in mind that's 28 psi on the wrong side of the valve (coming into the intake port) when the valve is closed.
I meant peak combustion pressure between all that boost and n/a
3tech
Compression, and cylinder pressure are not a factor in choosing springs. One has nothing to do with the other.
mwebb
FOG
Dallas
Feb 16 2010, 12:57 PM
suprf1y
what ?
ambient baro = about 15psi at sea level , a bit less at higher elevations .
boost = i dunno , 7 8 psi for most OEM turbocharged systems .
combustion pressure can get to 500psi , but most of the time very much less depending on conditions and the system involved ...
but not relevant as that will hold the valve closed .
and in a normal world the cam will not try to open the valve during combustion .
so peak valve seat pressure is not a function of the valve spring .
the spring s are tested at 28 psi
an NA engine may have 20" of vacuum at idle 25" on decel
vacuum peak of 12.5 psi which is being resisted by a 28 psi spring ...
that works
28- 12.5 = 15.5 in reserve , so you can not exceed 15.5 psi of boost and have the valve close
but there is no boost on decel.
what relationship are you referring to ?
earthtoad
google "Ferarra" or something like that........
