| 99 chevy metro Code P1250; Code P1250 | |
| Tweet Topic Started: Feb 12 2010, 07:32 PM (3,157 Views) | |
| metro99 | Feb 12 2010, 07:32 PM Post #1 |
i have a 99 metro 1.0 3 cyl , i am getting this code ,P1250 , some one told me to change the gaskets on the throttlebody , do you get them from GM ? , am i on the right track , i changed the plugs cap rotor wires , not for this code , just wanted to know where i was starting from with the car , i just got it 2 weeks ago , i am only getting about 31 MPG , but it seams like it is running ok ,so any help will help , Thanks I am new to the metro cars , Thanks Frank From Near erie Pa |
| Johnny Mullet | Feb 12 2010, 09:00 PM Post #2 |
Erie, PA? I used to work there ![]() Welcome to the site. P1250 - EFE Heater Circuit Malfunction Right click and "View Image" for full size......... ![]() You will need parts 10, 11, and 12 Check the wiring first before replacing the part. |
| metro99 | Feb 12 2010, 09:07 PM Post #3 |
with that bad , would that give me bad MPG, i am only getting around 35 MPG All round driveing . |
| Johnny Mullet | Feb 12 2010, 09:12 PM Post #4 |
Yes, especially in the cold weather. I would check a few junkyards like Jay's Auto Wrecking, Patterson's, or Community. I would get the whole throttle body unit just in case you need an injector or some other part in the future. Maybe you could bring that Geo to my house 40 minutes away and I could give it a checkup. |
| metro99 | Feb 12 2010, 09:15 PM Post #5 |
ill let you know , ill check around , Thanks ! |
| metro99 | Feb 13 2010, 11:18 AM Post #6 |
i just found the fuse, its a 30 amp , and it is blown , i put a new one in and in a few sec. it blows , i called the chevy dealer in town, they tell me they cant get the two gaskets any more , so now what , any one know where i can get the two gaskets , it is shorted out ,Thanks Frank |
| mwebb | Feb 13 2010, 12:33 PM Post #7 |
FOG
for the time being you could probably solder in a light bulb across the connection to the heater in the spacer plate the PCM will see a complete circuit and the CEL will remain out when cleared . then you can hunt around for the part and still use your car it probably is not functional when the engine is hot anyway |
| CityConnection | Feb 13 2010, 01:19 PM Post #8 |
Sir, yes sir!
If there isn't a source for those gaskets you may have to do it the old fashioned way... make them. If you are careful when removing them you can use them as a template. Check in you local parts store for "gasket paper" or "gasket sheet" or if they still stare at your like you've got 3 heads... tell them you need to cut a gasket to replace one that isn't made anymore. This one should be pretty easy as there isn't any fluids being transferred through the gasket. Just trace the old gasket onto the sheet and then cut it out. A hobby knife (thin blade that tapers to a point and mounts in a solid handle, look in the plastic model section of a store) will be much easier than scissors or a razor blade. Replace the gaskets and enjoy! |
| Johnny Mullet | Feb 13 2010, 01:22 PM Post #9 |
Gasket #10 GM P/N=91172182 from dealer AC Delco=219-276 FEL-PRO Part # 61030 Gasket #12 GM P/N=91172181 from dealer FEL-PRO Part # 61095 |
| metro99 | Feb 13 2010, 04:29 PM Post #10 |
got the two gaskets comeing from Autopartswherehouse about $31 for the set with the S/H, Thanks Frank From Near Erie Pa , Thanks Jonhnny Mullet, That Sure Helped ! |
| Johnny Mullet | Feb 13 2010, 05:52 PM Post #11 |
Now be sure to come visit us at GeoPalooza 2010............ http://geometroforum.com/topic/2288027/ |
| metro99 | Feb 13 2010, 07:49 PM Post #12 |
where is that at and when ? |
| Johnny Mullet | Feb 14 2010, 07:52 AM Post #13 |
It is posted on the main page............. http://geometroforum.com/site July 24th-25th and the location will be announced soon. |
1:54 PM Jul 11
