| Ram Air Geo Pictures | |
| Topic Started: Feb 13 2010, 01:44 PM (1,839 Views) | |
| starscream5000 | Feb 17 2010, 08:28 AM Post #31 |
AKA 95_G105spd
I think it was called a corrado? |
| JAMES | Feb 17 2010, 08:47 AM Post #32 |
IT'S NOT HOW FAST YOU ARE ,BUT HOW GOOD YOU LOOK GETTING THERE.
| bogs | Feb 17 2010, 12:32 PM Post #33 |
SOOOO true And yah @ Cobb, I sure doubt anything the factory offered as stock would be prone to easy failure since they would have to fix it for the first few years. Obviously any engine can fail if abused past its point of limit, i.e. flooring it away from every stoplight supercharged or not. Did not know they offered dealer installs of that, thought they were all factory installed units
| Mr Murf 59 | Feb 20 2010, 07:06 PM Post #34 |
Yeah BABY!
| geoman | Mar 3 2010, 10:47 PM Post #35 |
Hey, What do you use the winch for? Is that Metro all wheel drive? Then its a Tracker! Hah |
| BryanTheGhostRider | Mar 4 2010, 02:08 PM Post #36 |
Just call it a low rider then lol |
| 3cylgeo | Mar 31 2010, 02:57 PM Post #37 |
there must be a reason the chevy cobalt ss went turbo and got faster than its supercharged predecessor. |
| metro_fiend | Apr 17 2010, 02:04 PM Post #38 |
I was on youtube and found this
Edited by metro_fiend, Apr 17 2010, 02:04 PM.
| chads4drhatch | Apr 17 2010, 04:42 PM Post #39 |
Thats why you use both! Supercharger for your low to mid power....and a huge turbo for your top end!
| bogs | Apr 17 2010, 08:36 PM Post #40 |
I think I would stick with one or the other heh heh.
| Bad Bent | Apr 17 2010, 11:00 PM Post #41 |
Thanks, metro_fiend. I haven't heard from my friend in a while but I guess he is having to much fun driving his Geo to make any postings, eh. Someone found his car and likes it.
| Barton | Apr 17 2010, 11:02 PM Post #42 |
If the proper turbo is selected with close flow characteristics as the engine the boost will be almost instant. Same can be said with a supercharger however it's an endless debate because of the many types of turbos and superchargers that have been build. Many Sc's will fall on there face because they stop flowing at a certain rpm while others don't work hard until higher rpm's. It's all in the cfm you want to produce from to power adder and what you want from it. Just remember psi is considered a flow restriction, pumps don't build pressure restrictions do! With that being said I wounder if the wife you be upset if I put my m90 on the Geo lol. |
| Mr Murf 59 | Apr 18 2010, 05:10 PM Post #43 |
In the way back. The drag racers used to put the C.I.D on their front fenders or hoods. With our engines being 993 cc's. What would that be in CID? Then what would it be for a 1076cc engine? |
| starscream5000 | Apr 18 2010, 11:40 PM Post #44 |
AKA 95_G105spd
60 CID from what I remember. |
| CityConnection | Apr 19 2010, 12:18 AM Post #45 |
This is you, so you must be online
Very true. Example: engine makes 200HP on 8PSI of boost... after replacing the intake manifold with a custom fabbed one the engine makes 220HP on 7PSI of boost. Having owned both supercharged and turbocharged cars I know the ups and downs of them both. That said, I'd love to see a supercharged 1.0! |
| « Previous Topic · Pictures/Videos · Next Topic » |
SOOOO true
5:06 PM Jul 30
