| warm engine idling too low... | |
| Tweet Topic Started: Feb 18 2010, 12:29 AM (822 Views) | |
| heaveninbc | Feb 18 2010, 12:29 AM Post #1 |
Nothing but a noob here
Hello,I have a 95 geo metro 3 cylinder,5-speed.I just rebuilt the engine with new pistons,rings,and a fresh top end.It idles great when cold,but when it warms up it not only idles crazy low,but also the oil light flickers on and off as well.what could be wrong? I don't see an idle adjustment anywhere on it and it doesn't appear to be consuming any oil either.any help would be greatly appreciated on this.thank you all in advance-Dan
| obaja | Feb 18 2010, 12:36 AM Post #2 |
Diesel Power
try adjusting the tps. there is a thread on it. mark it before you move it from where it is now though.
Edited by obaja, Feb 18 2010, 12:37 AM.
| Bad Bent | Feb 18 2010, 05:25 PM Post #3 |
You could try clicking on swift.hit.bg/3EN and scroll down to R33 - Idle Adjust. On the right are G, L and M. G is Google. I got 'M' to open faster.
| starscream5000 | Feb 18 2010, 06:30 PM Post #4 |
It could also be your timing. What is it set at? |
| chads4dr | Feb 18 2010, 09:38 PM Post #5 |
Yup..... TPS or Timing, in my case it was the TPS needing adjusted. TPS REPORT |
1:54 PM Jul 11
