1.3 distributor
Topic Started: Feb 21 2010, 11:43 AM (502 Views)
jellybean
is there a fix for a leaking distributor? seams to be internal and leaks into the cap area dealer said i need a new distributor
If you remove the dizzy, take it apart, and you will find a seal in there for the dizzy shaft. I am not sure if you can find another seal so most of us get a junkyard dizzy.
jellybean
Thanks likely get one from the jy just wanted to know, had the same problem with a 4age real bad and real common with them
