92 g10 engine in a 96?; compatability of 95 and older g10 engines with 96 and latter cars
Topic Started: Feb 23 2010, 02:38 PM (739 Views)
jdgFirefly
Hi I have a 1996 firefly with the g10 motor. It is in rough shape and needs an engine rebuild however I need to continue driving it. So I found a low mileage engine from a 1992 in the junk yard. I pulled it and sent the block to the machine shop and the head I was going to send to 3tech performance. however mike at 3tech pointed out that my 96 has a crank sensor mounted into the front of the block.
My question is, can this sensor be transferred to the older block? And is there any other incompatibility issues I'm missing?
I think the sensor is mounted into the oil pump housing so I don't see why the newer oil pump with the sensor can't be transferred to the older block, but I really don't know.
thanks
starscream5000
I may not be right on this, but I would think that you'd just need to get the '96 and up oil pump... :hmm
You need these 96+ parts.............
Oil pump
Crank Sensor
Oil pan
Timing gears (both)
Timing Belt
Timing cover
jdgFirefly
Thanks
It doesn't sound like its much of a problem using an older engine. I started to panic a bit when i found out that there was a crank trigger sticking out of the block. I previously owned a 95 and I guess I assumed it was the same. I lost all confidece when I talked to a suzuki mechanic that told me that the engines are totaly different and can't be swaped. I guess some mechanics only know how to read part numbers out of a database.
thanks again for your help
Welcome to the forum, jdgFirefly! :coffee
Join in the frivolity! :lol
metroschultz
Totally doable
I've swapped the older motors into the newer cars twice, and Cobb has a 92 long block in his 99.
