noise coming from head...
Topic Started: Feb 24 2010, 06:25 PM (1,480 Views)
metropuller
what should be the oil psi at idle, on my engine oil press is around 18 at idle goes up as i rev!
Edited by metropuller, Feb 25 2010, 09:29 PM.
metropuller
bump
Is that 18psi when its warm. If this is a new engine. Did you build it or is this a crate engine? If its a crate engine. I would call the builder, and find out. Your oil pump is either putting out low pressure, or there is a restriction. Now our motors do sound kind of funny when they idle. Mine kind of chrips.
metropuller
Mr Murf 59
Feb 26 2010, 05:00 AM
no 18psi on start up? i bought the short block and head,then put it together.
