| TPS % or v. | |
| Tweet Topic Started: Feb 26 2010, 02:41 PM (831 Views) | |
| jellybean | Feb 26 2010, 02:41 PM Post #1 |
My tps percentage is 20 at closed and volts are .99 and idle is around 8-900 but the idle control motor never moves when cold is the percentage to high for the idle control to kick in ? this is on the 96 1.0L |
| mwebb | Feb 27 2010, 02:50 PM Post #2 |
FOG
in a perfect GM world ... TPS minimum voltage should be around .5 volts and Absolute TPS minimum should be 0% your generic tool shows absolute TPS i think actual TPS will be a bit over 0% which is what enhanced scan tools will display |
| jellybean | Feb 27 2010, 05:41 PM Post #3 |
thanks for that I'm just trying to figure out the cause for the isc not working and that % seems crazy when the throttle is closed but cpu seems to be more concerned with the volts to regulate the isc . picked up another used isc but it acts like the gears are stripped so next move is to swap gears but i have yet to get the gear off without damaging it, looks like it is glued on the motor shaft |
1:54 PM Jul 11
