| Metro frame and body repair.; Rust! | |
| Tweet Topic Started: Apr 7 2010, 03:48 PM (3,793 Views) | |
| starscream5000 | Apr 7 2010, 03:48 PM Post #1 |
I will most likely be having metroshultz do the repair work on must jellybean. The frame horns are rusting (no surprise) as well as the side skirts and the rear fender wells are almost gone. I've knocked out the rusty portions in the rear fenders and filled them with expanding home insulation foam as a band-aid fix for now. I was getting drenched while driving in the rain, so that got old really fast. I painted the foam so it wouldn't be such an eye sore, as well as painted the sides of the car with a primer that would adhere to rust, but as you can see, the cancer continues. Pictures below: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
| starscream5000 | Apr 7 2010, 03:49 PM Post #2 |
Comments and suggestions are welcome! |
| GeoStalker | Apr 7 2010, 04:15 PM Post #3 |
Were the forward frame stands welded, or was some other compound use to reinforce? It almost looks like bondo was used on them or something. I would investigate that (use a magnet over the areas for which you're unsure) and get those bad boys welded where they need it. As far as the rear of the car in the hatch compartment, that's a non-weight bearing area until it creeps over to the shock tower...then you may have an issue. I would recommend hitting the rust with Ospho or some other hardening agent before foaming. I happen to be an advocate for Great Stuff foam in the body of these cars as fillers as long as the rust underneath is first treated. |
| starscream5000 | Apr 7 2010, 04:20 PM Post #4 |
Nothing has been done to them at all yet I think you may be looking at the tar-like coating on the frame itself that was placed on the car when it was new. It's also a little oily down there as well, so that may make things look a little weird too. That and these pictures were taken off of a cell phone.
Edited by starscream5000, Apr 7 2010, 04:21 PM.
| Bill CNC | Apr 7 2010, 05:04 PM Post #5 |
Would it not be easier and SAFER, to just find another Geo of the same year(s) that have a blown motor, or trans is messed up, or the interior is just shot to hell, ... and then transfer everything over to the new rolling chassis? It seems to me that it's more work replacing all the bad metal only to have to do a crap load of body work, to end up with what another chassis could provide you, ... SAFETY! Just asking ....
| starscream5000 | Apr 7 2010, 06:57 PM Post #6 |
You'll not find a good rust free geo around here. I've put too much work into this car to back away from it. |
| Bill CNC | Apr 28 2010, 10:01 PM Post #7 |
One nice thing about cars from the California desert, ... What's Rust?
| UsdiThunder | Aug 31 2010, 09:32 AM Post #8 |
I just bought a 1997 Geo Metro for $400. All that was wrong with it was that the CV shaft was broken. So I thought it was a good deal and had the Car towed to my home so I could work on it. When the Tow truck raised it up there was a loud sound and we saw that the frame has busted. I've been online and seen so many things about getting this welded and fixed, but every car shop around here keep saying they won't do it due to liability. Does anyone know of anyone in the SW ohio area that does do this repair? |
| PA.metro,fixer,frames,ect | Aug 31 2010, 09:58 AM Post #9 |
Frame Fixer
fixin frames is how i got invited to the metro site,, jonny has seen my work, have refs if you want,,,fyi -i fix it right, no short cuts, and couple trade secrets,to make it stronger and last longer................... and yes no one wants to do it right-- is misrable lot of rust in your eyes grinding shit in your face work- and days of work....... 150.$ per side.... usally have to fix --- ha always have to fix floors to.... i also fix rear wheel wells- welded in, with metal,, i use factory body and seam sealer, and por-15 to stop rust.............bla bla cell 724 699 6244 |
| bogs | Aug 31 2010, 12:07 PM Post #10 |
Probably no better offer than that one
| Johnny Mullet | Aug 31 2010, 04:46 PM Post #11 |
| todaugen | Aug 31 2010, 10:27 PM Post #12 |
Damnit, We need someone like that here in the midwest. I'd fall over dead on the spot if someone actually said they could help me and were in my backyard. And his price actually looks reasonable. Jesus. That's it--I'm moving somewheres else. |
| metroschultz | Sep 1 2010, 08:42 AM Post #13 |
todaugen, For what you were quoted from the one shop, you could rent a truck and trailer and take your Metro to PAFixer. Then turn in the truck and trailer and drive the Metro home. My Brother did that when his Head gasket blew in Toyota Supra. Local Shop = $3500 Shop I worked at = $1800 U-Haul = $350 Time of from work 3 days. (fixed over a weekend) |
| bogs | Sep 1 2010, 10:20 AM Post #14 |
Heck, I'd do it that way just to get the 3 days off
| jeff | Sep 1 2010, 11:57 AM Post #15 |
Todaugen check into learning how to weld. At the factory we used 11oVolt welders on The Ford GT-40. (Certain application) You'll discover how you couldn't live without your welder. |
7:12 PM Jul 10
