Exhaust manifold -- How do you know when to it's gone bad and needs replaced?
Topic Started: May 12 2010, 08:44 PM (7,027 Views)
Metro_caon
Ok so how can you tell when it's time to replace your exhaust manifold?
crankcase
I guess if it's cracked? I've never seen one go bad. You should clean the EGR (exhaust gas recirculation) port, I would say at least once per year. It gets clogged easily. If you have a loud exhaust leak, I would replace the 2 gaskets. The one at the pipe is often over looked.
Jittney
I found my leaks with Seafoam. This link will explain it.
http://geometroforum.com/topic/681815/1/
smokstac
Every 1.3L exhaust manifold I have personally seen has a crack between #2/#3 ports along the backside of the casting.
Replace your exhaust manifold when your car sounds like a log truck.
Jittney
May 12 2010, 09:28 PM
Do you have pictures or video or is it obvious? As crankcase points out there are two gaskets. I have a bad manifold because the threads are crossed where the Cat connects, the two springs. Could not get a full seat on the "donut." I replaced the donut gasket and the manifold, reused the other gasket.
mwebb
FOG
crankcase
May 12 2010, 09:09 PM
yes
it is this simple - either the manifold is broken , or
it is not broken ....
but
if it broke because of UNeven temperature betwixt the runners , think on WHY that might be
could it be because the cyclinder associated with the broken runner was out putting unburned HC and 02 ?
which then burned in the manifold ?
making it very hot ?
causing UNeven expansion and funny events in the metal ?
you betcha .
now think;
where did that extra HC and 02 come form ?
does misfire cause more HC and 02 to get into the exhaust ?
you betcha .
smokstac
Could be a design flaw as well.
mwebb
FOG
smokstac
May 12 2010, 11:59 PM
could be
but
at 114 k miles , mine is not cracked or broken -
of course i have been told that my car is "special" .
and
my Momma said that i was " special "
but
if there were a design flaw , i expect mine would be broke by now ....
of course then again , my engine is not misfiring.
Or it may be a design flaw like the infamous front horns, which shows up on some, but not on others, etc.
mcmancuso
All the 4cyl 16V manifolds are cracked, in the same place, samp has also seen this. It's a defect in the design :(
mwebb
FOG
mcmancuso
May 13 2010, 12:54 AM
...."Location
IL
Year/Make/Model
91 geo metro"....
the OP has a 1991 geo metro
were they available with G13 engines ?
Metro_caon
crankcase
Well, the exhaust manifold is NOT cracked, however, it is burned pretty bad, which got me concerned in the first place. Also, I found the 'donut' after the exhaust manifold is burned as well, and loose, which I think is making the car somewhat noisy.
crankcase
It all sounds ok. They normally look a little burned, mainly rusty, but not too different than any other exhaust component. Black would be a bit odd.
You should be able to replace the round gasket and make it sound better. You many want to let the exhaust bolts soak, especially the ones with the springs, in a good coat of Liquid Wrench before attempting removal. Reinstall with some exhaust anti sieze.
If you are going to have the manifold loose, check the EGR passage. It goes from the exhaust, through the exhaust manifold and on through the head, and then around to the the EGR valve. You can check it by working the EGR plunger by hand. It should want to stall the vehicle if normal; if there is no change in idle it's clogged.
Nick
Jack Of All Trades Master Of None
mine is completely rusted any issues i should worry about?
