| Doing the brake/knuckle upgrade today - Need torque specs | |
| Tweet Topic Started: May 29 2010, 04:03 PM (1,184 Views) | |
| JellyBeanDriver | May 29 2010, 04:03 PM Post #1 |
I'm doing the knuckle/brake upgrade on my 92' today with parts off a 2000 Metro. I need to know torque specs for: - Caliper mounting bracket to knuckle (not the caliper slider pins) - ball joint to knuckle bolt Thanks! Dave (BTW, has anyone seen balanced rotors on the metro? Do they come balanced from the factory?) |
| SkitZoid | May 29 2010, 04:18 PM Post #2 |
Hiya, not totally sure if these are the right specs that you need, but looking at the Hayes manual.. it gives "Knuckle-to-control arm pinch bolt" 44ft lbs and "Caliper mounting bolts" 20 ft lbs or 30 Nm |
| JellyBeanDriver | May 29 2010, 04:36 PM Post #3 |
Thanks, the pinch bolt is what I want. The caliper mounting bolts though isn't the same as the caliper bracket to knuckle. I think I found a link that said it was 51-72 ft lbs for the caliper bracket |
7:44 PM Jul 10
