after market wheel that would fit a 92 metro..sm wheel lugs
Topic Started: May 30 2010, 09:57 PM (1,421 Views)
metropuller
Do they make a wheel that fits on a 92 metro. My car has the small studs and lugs.
GeoStalker
By "wheel" do you mean 4 x 4.5 inch or 4 x 114.3 millimeter size rims? The 92s were 12" rims with that lug pattern. Or are you talking about upgrading to something else?
JellyBeanDriver
metropuller
Yep, they came from the dealer with wheels installed. :P
Gorilla makes some larger lugnuts that fit the small 10mm studs so you can put different wheels on.
Just need to search for wheels that fit (like 13" steel ones from 95+ metros)
metropuller
JellyBeanDriver
May 30 2010, 11:10 PM
metropuller
sorry guys i should have put that i wanted to up grade the wheels to a after market type in the post. I was thinkin maybe 14in? Where can buy those lugs?
JellyBeanDriver
Here they are. Shop around using that pn.
http://www.brandsport.com/grla-41118.html
mcmancuso
any aftermarket wheel with the 4x4.5" (4x114.3mm) lug patern will bolt on, bigger than 15 is a no go unless you want to buy really expensive ultra low profile tires, roll your fenders or lift the car. 14" wheels with 195/65/R14 is about as big as I'm going to go on mine, you can get a similar outer diameter tire in a 15" wheel but it costs more being a lower profile. national tire & battery has some nice wheels in 13" and 14" for ~60 each
hotdiesel80
i bought a vw rabbit and bought mags from pepboys ,ended up selling the car with out the rims , bought a geo 94, after some time i thought maybe thoughs rims and tires may fit -- these rims have 8 holes , and maybe ,the second patteren may work , 4x100 not good ,rotated to second hole pattern and prefect so the rims must fit several modles -- smart idea --- 14 x4 x ? but they work ,i think i payed 49.95 for each rim 450 with tires ,balance ,stems .40,000 mile rating , have 48 on them now and it looks like 20,000 more to go !
metroschultz
Many smaller aftermarket rims will be drilled with the dual bolt pattern.
Easiest just go and see.
