| NEED to RE-DO my oil pan GASKET | |
| Tweet Topic Started: May 31 2010, 02:49 PM (997 Views) | |
| Alpine | May 31 2010, 02:49 PM Post #1 |
1020cc G10 GOML
alright well the first time i failed, well i dindn't really fail i let my mom apply the RTV sealant i have some black RTV and was wondering if what i did last time was correct. on the bottle it says the wait X amount of time so it doesn't bond both parts together my mother said that was right do i want to put the RTV on then apply ASAP or wait the time specified? |
| wikityler | May 31 2010, 03:09 PM Post #2 |
Some say...
What kind of RTV are you using? Any of the stuff I've used wants assembly to be right away. |
| CityConnection | May 31 2010, 03:25 PM Post #3 |
Sir, yes sir!
depending on what it says on the tube, there might be a waiting period before assembly. This allows the RTV to well... V (vulcanize). It becomes slightly stiffer and tacky. This will allow the RTV to spread out without becoming to thin in areas when the surfaces are mated and then tightened down. |
| Alpine | May 31 2010, 03:52 PM Post #4 |
1020cc G10 GOML
i have two , ones global and permatex |
| 96Geoman | May 31 2010, 03:56 PM Post #5 |
![]() The Red RTV is tough. I used it on my oil pan and to seal a torn CV Boot. |
| Alpine | May 31 2010, 04:47 PM Post #6 |
1020cc G10 GOML
with permatex do i apply right away??? |
| 96Geoman | May 31 2010, 05:42 PM Post #7 |
Clean both surfaces with brake / parts cleaner. Apply silicone on the bottom of the block with a single bead, trace around bolts and bolt holes. After applying silicone, immediately install oil pan finger tight until you start seeing the silicone seep out and STOP, Wait a couple of hours for the silicone to cure. After 2 hours, tighten bolts 1/4 to 1/2 turns. The Directions... http://www.permatex.com/documents/tds/Automotive/81160.pdf Dan Edited by 96Geoman, May 31 2010, 05:43 PM.
7:41 PM Jul 10
