Replacing radio. 99 metro; Duno which radio can fit in
Topic Started: May 31 2010, 04:49 PM (1,160 Views)
yoshiki2
I just bought a 99 metro, and I just fixed the transmission. Next step is the radio (stereo).. where can I buy a radio that fits in.. my am/fm tape player is huge.. so I duno if I can buy any radio and make it fit???
Am completely newbie to this.. thx 4 the advise
zippy
go to crutchfield.com they will show what will fit or what you need to make it fit
Geo Whisperer
Even AutoZone and other parts stores have radio installation kits to help you out. Got any friends who do stereos? Maybe they can help advise.
Welcome to the forum, yoshiki2! :coffee
Congratulations on the transmission fix. :thumb
mcmancuso
You will need the GM adapter insert (Scosche Gn2200b), then any radio will fit the hole, you will also need the GM-import wiring harness adapter (Scosche brand GM05B) you should be able to get these cheaply at walmart or online. With these any single DIN radio will fit there. make sure you get connectors, the stereo you buy will come with a plug and bare wires, you have to connect these wires to the wiring harness you buy, then plug that into the dash.
yoshiki2
thx 4 the welcome.. I found this item on ebay.. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380233069411&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=f033b23d1280a0aad46655e6fed6f2fa&rvr_id=&ua=L*S%3F&itemid=380233069411#ht_632wt_909
98-01 CHEVY METRO RADIO STEREO INSTALLATION KIT NEW
I also found this http://cgi.ebay.com/2000-2001-CHEVY-METRO-RADIO-DASH-KIT-WIRE-HARNESS-ANT-/120349849838#ht_4384wt_1139
2000-2001 CHEVY METRO RADIO DASH KIT/WIRE HARNESS/ANT
whit this an I plug any stereo I wish??? my other option would be any in-dash navigation sytem.. any cheap one available??? B-)
Edited by yoshiki2, May 31 2010, 09:11 PM.
Cobb
Cheap and nav in a single head unit are two words you can not use together.
You car get a gps for under 100 bucks at most stores. You can also get a nice single din and in some cases a double din radio that plays cds, mp3s, usb, etc for under 50 bucks with speakers.
I like sony head units and kenwood speakers myself. I got a garmin for 110 bucks a few years ago.
Then once you get the radio, get the ahrness and match the colors and plug into the car.
yoshiki2
I found this one @ new egg.. http://www.newegg.com/Product/Product.aspx?Item=N82E16882647053
Clarion 2-DIN Bluetooth CD/USB Receiver with CeNET Control Model CX609
chassis size: double din.. will it fit my car without buying an external mount?
crankcase
I have not bought a mounting kit ever. It is not hard to do a good install if you are patient and take your time to get it right.
This is perfect type project for a do-it-yourself type, if you like that sort of thing. The mounting bracket that come with all
new radios I've seen have folding tabs all along the edge you canbend as needed to hold the radio in place. You adjust
(bend the tabs) on this plate for a flush fit so that half the radio DOES NOT stick out past the dash. A flush fit makes it
look good! There will be a bezel/cover that you put on over this bracket to hide it and make it look neat. You will need to
support the rear of the radio so it won't sag with some plumbers strap etc. I have also used a
block of wood, but my favorite is an old sock (ewwww).
MrBlack
The double din trim for this is Scosche GM1590AB for those interested. http://www.amazon.com/Scosche-GM1590AB-Double-1992-Up-General/dp/B000NWG3RO
Cobb
Really any double din or single din. You can get the adapter for the opening and harness at any advance auto as well as other auto stores. In metroschults car we put in a scion radio, its a double din and used Camry connectors to wire it up.
Jezza
Boost Junkie
I'm running a Pioneer DEH-2300 single din in my 91 Metro. Its a great aftermarket swap! Powers my 8" Blast King mids and tweeters and I'm thinking of putting my subs on it as well ...
Not ready to put in amps as yet :smackface
