| Mysterious Oil Burn Problem; Burns oil - unusual compression results | |
| Tweet Topic Started: Jun 1 2010, 12:49 PM (1,503 Views) | |
| c140flyer | Jun 1 2010, 12:49 PM Post #1 |
Hi Folks, I've had my '92 Metro now for over two months. I've had a lot of small problems which I've actually enjoyed the challenge of resolving (lots of wiring issues, window regulator probs, oil leaks, radiator leaks, etc.). The previous owner had done some "creative rewiring" and mentioned that he also had done a cylinder head job. I was going through 1 1/2 quarts of oil every 400 miles. I had an oil leak that would leave puddles of oil everywhere I parked. It took me a while to figure out the problem. After replacing the distributer o-ring ring twice and valve cover gasket, the leak persisted. Finally I read where there was a gasket between the distributer housing and head that I found missing. Made a new gasket and the engine compartment was dry as a bone. I assumed that the oil usage problem was over. Not so! I'm still going through a quart every 500-600 miles. The engine I sold from the '96 never needed oil between changes. When I bought the car, I'd performed a dry compression test . #1 - 185, #3 - 180, #2 - interesting. The first reading I took for #2 showed 120 after 5 seconds of cranking (with throttle open). I cranked again and got 175. The car ran great,so I figured that I messed up the first time. As I said, the car runs great. I'm getting 53-55 MPG and it has lots of power. I thought it might have something to do with the PO using a head gasket with small oil return holes. I checked the PCV valve and it looked OK. I redid the compression test dry and wet with the car at normal operating temperature.. #1- 180 dry/190 wet -good #3- 175 dry/185 wet -good #2 (drum roll)... bizzare results: 60 dry (first test), 90 dry (2nd test) 0 (as in zero) wet (first test) 90 wet (second test). I buttoned it up and drove it around the block and retested #2 again. I got 180 dry and 195 wet! Not sure what to check next. I thought I might try a leakdown test. Someone at work thought I could have a bad lifter or a stiking valve. Not sure how that would affect oil burn rate. Any suggestions? I'm almost hoping someone will find something obvious and make me look like an idiot! Thanks, Larry |
| slander | Jun 1 2010, 12:54 PM Post #2 |
Tech Certified
If it's coming from that side of the car, is there still oil coming from the underside of the distributor? If not, yet it still coming from that side of the car, check your rear main seal. EDIT: Forgot to add, if you're getting 50+ miles to the gallon, the car runs well with good horsepower, and you're getting funky readings like that, I would be skeptical of your pressure tester. Edited by slander, Jun 1 2010, 12:58 PM.
| bennie442 | Jun 1 2010, 01:09 PM Post #3 |
A bad cam seal or crank seal will lose engine oil without getting your engine compartment messy. Look at the bottom of the timing cover. See any oil? |
| c140flyer | Jun 1 2010, 06:09 PM Post #4 |
I think you guys are right about the cam/crankshaft seal oil theory. I do have some oil there, but it doesn't drip like the other leak did. When I fixed that leak, it only reduced the consumption by a few ounces per tankful, but hopefully you're right. I'll pull the cover when time permits. I think the compression problem is a separate issue. I think the gauge is OK, because the results of #1 and#3 are consistent. It's probably a stuck valve or lifter problem. From what I've seen of the PO's work, he probably screwed up the valve job . Thanks, Larry |
| mcmancuso | Jun 1 2010, 06:25 PM Post #5 |
You might have a bad oil ring that's letting oil into the cylinder? don't know if this would have a negative effect on compression but it would let it burn oil. |
| nerys | Jun 1 2010, 06:59 PM Post #6 |
Grr
Also check your threads on that spark plug hole. Might eliminate compression as the problem IE if its intermittently not SEALING properly you would get those wonky readings. |
| crankcase | Jun 1 2010, 08:09 PM Post #7 |
Stuck rings mucked up with lacquer might be causing those types of readings and symptoms. I've heard of people adding lacquer thinner to the cylinder and working the crank by hand (repeat a few times) to free things up. After doing this the oil & filter must be changed. |
| mwebb | Jun 1 2010, 09:41 PM Post #8 |
FOG
..."I redid the compression test dry and wet with the car at normal operating temperature.. #1- 180 dry/190 wet -good #3- 175 dry/185 wet -good #2 (drum roll)... bizzare results: 60 dry (first test), 90 dry (2nd test) 0 (as in zero) wet (first test) 90 wet (second test). I buttoned it up and drove it around the block and retested #2 again. I got 180 dry and 195 wet! "...if you connect a vacuum gauge Teed into the MAP sensor vacuum line BEFore the restriction orifice . intake vacuum MUST be around 20" at hot idle with ZERO flutter if you have intermittent flutter , you have a valve problem . also using the wrong oil will cause this the oil in the engine MUST NOT be 10w40 or 20w50 .... for best results and longest engine life the best oil is European specification ACEA A3 B3 - B4 5w30 synthetic oil it is also the Cheapest as in most frugal to use |
| nerys | Jun 1 2010, 10:27 PM Post #9 |
Grr
"ACEA A3 B3 - B4 5w30 synthetic oil " how about just telling us what brands of oil in the US meet this specification. I HAVE NEVER ONCE seen a label that said "ACEA A3 B3 - B4 5w30 synthetic oil " its always variations and inclusions etc.. etc.. XXX and all previous etc.. give us a brand and model or oil that is ACEA A3 B3 - B4 5w30 synthetic oil |
| mcmancuso | Jun 1 2010, 11:45 PM Post #10 |
I agree give me a brand I too have never seen those specs on a bottle. the mobil 1 I buy says: ILSAC GF-4 ACEA A1/B1, A5/B5 API SM, SL/CF GM 4718M GM 6094M Honda HTO-06
| c140flyer | Jun 2 2010, 11:47 AM Post #11 |
You mean I can't use 85W90 gear oil in the engine? Just kidding. I use Mobil One semi-synthetic 5W-30. I used it in all my cars for the last 2-3 years with no problems. I'll take a look at vacuum. I just found a neat compound gauge that should work. I also have a differential leakdown tester that I use on aircraft that needs to be adapted to 14mm sparkplug threads (a/c are mostly 18mm). That should tell me the source of the leak plus give me another data point. Thanks, Larry |
| Coche Blanco | Jun 2 2010, 11:55 AM Post #12 |
Gear oil is too thin. I use bearing grease. |
| mcmancuso | Jun 2 2010, 12:52 PM Post #13 |
LOL! Man just step up and run paraffin (oh and make sure you have a block heater on it when its not running) That'll stop the oil burning and leaks
![]() ZetaBoards gives you all the tools to create a successful discussion community. Learn More · Sign-up Now |
7:41 PM Jul 10
