very odd problem; my shop dont know whats wrong
Topic Started: Jun 9 2010, 08:27 PM (1,472 Views)
kiwiee
well shop looked at it and replace the filter bag on the fule pump now i gota get it below half a tank to test it will take sum time
mwebb
FOG
if you remove the RETURN fuel line (smaller OD) from the throttle body
and replace it with a length of 8mm / 5/16" clear plastic line , you will be able to see the fuel going back to the tank .
if
there are lots of bubbles in that line DURING your problem , then either the new fuel pump is KAKA or
it is sucking air inside the tank because something in the plumbing in or near the fuel tank is KAKA...
another way would be to monitor 02 sensor voltage
if voltage stays low , around 100 mv during the problem , but cycles between 150 and 850 mv when the problem is NOT present
then again
you have a fuel delivery problem
remember
NEW
means
NEVER
EVER
WORKED properly
NEW
and if it says "china" anywhere on the NEW Fuel pump and it was shipped in a plain white box
it was defective before it was installed
kiwiee
ill try that if problem not fixed thnks
JellyBeanDriver
mwebb
Jun 10 2010, 10:58 PM
if
Good idea! I'll have to remember this.
