| CAR NOT RUNNING RIGHT HELP | |
| Tweet Topic Started: Jun 18 2010, 01:44 PM (990 Views) | |
| Georacen09 | Jun 18 2010, 01:44 PM Post #1 |
I have a 95 geo metro 2dr 5sp 3cyl 131k miles i have done a complete tune up wires, plugs, fuel filter, cap and rotor when it warms up going down the road with a constant speed it will act like it is running out of gas and then will just go again and wont stop. if i pull over and shut the car off for a minute i can drive a little further and then it happens again. While driving down the road i can turn the key off and then turn it back on and it will run a little long and then act up act...........dont knw were to start can anyone help me Edited by Georacen09, Jun 18 2010, 01:45 PM.
| crankcase | Jun 18 2010, 02:13 PM Post #2 |
There are a few things that would cause your symptom, often the check engine light will be on. The bulb could be out, so verify it is showing an all clear code to verify the bulb is good. Check the plug wires etc. to make shure they are on tight. Did any of the old plugs look black and oily or were they light tan? A compression test is high on the list of things to check, especially if one or more of the old plugs were black. It's not hard to test, there is a ton of info and here, including a write up in the how to section. Edited by crankcase, Jun 18 2010, 02:16 PM.
| Georacen09 | Jun 18 2010, 02:31 PM Post #3 |
well the plugs didnt look to bad normal wear kinda black and all plugs are good and tight check engine light is on but not really sure how to check codes |
| Georacen09 | Jun 18 2010, 02:35 PM Post #4 |
i done the fuse thing to get the codes and it flashes 2 time stops and then flashes 3 times??????? |
| Georacen09 | Jun 18 2010, 02:40 PM Post #5 |
Would the IAT scensor cause the problems i am having |
| Georacen09 | Jun 18 2010, 02:50 PM Post #6 |
ok this is what i have 23 IAT Sensor Circuit 42 Crank Angle Sensor Circuit 31 Pressure Sensor Circuit Ok anyone wanna help me through this with pictures on were they are all located |
| Johnny Mullet | Jun 18 2010, 02:56 PM Post #7 |
Slap a new distributor in that for the main problem. The IAT is plugged in the side of the air cleaner. |
| Georacen09 | Jun 18 2010, 03:00 PM Post #8 |
will the distributor help a lot |
| Johnny Mullet | Jun 18 2010, 05:01 PM Post #9 |
Crank angle sensor = bad distributor. |
| mwebb | Jun 19 2010, 12:45 AM Post #10 |
FOG
3 circuit DTCs all at the same time ... heluva coincidence .... check the grounds at the back of the intake manifold check 5 volt reference on the MAP sensor or TPS |
| metroschultz | Jun 19 2010, 09:05 AM Post #11 |
| Georacen09 | Jun 19 2010, 11:48 AM Post #12 |
is there anything special i should do before i pull the distributor this is the first time i have pulled one |
| beachbummm | Jun 19 2010, 11:57 AM Post #13 |
I had the same problem after changing the plugs, try it with the old ones reinstalled...the store sold me the wrong ones |
| mwebb | Jun 19 2010, 06:58 PM Post #14 |
FOG
buy the correct torx bit it's very difficult to tell with out any test results but if you follow the test do not guess theory , you should get out your DVOM and make the tests suggested above FIRST . before removing ANYTHING . if you must take something out take out the head light bulb , it is easy and it probably will do just as much good as guessing at which part to replace . yes this may sound a wee bit sarcastic , too bad , it's not meant to be that way , it is also very true . Edited by mwebb, Jun 19 2010, 07:03 PM.
7:40 PM Jul 10
