| no power | |
| Tweet Topic Started: Jun 19 2010, 10:42 PM (535 Views) | |
| lond | Jun 19 2010, 10:42 PM Post #1 |
finally got helped through the ecm problem but noe i am severely lacking power. runs smooth and quiet just no get up and go it does ok but not good if i manually shift the automatic any thoughts would be great |
| Jittney | Jun 19 2010, 11:36 PM Post #2 |
It would be helpful to post your mileage and compression test results. |
| JellyBeanDriver | Jun 19 2010, 11:42 PM Post #3 |
Was it ever fast or is it just that this is your first automatic metro? |
| lond | Jun 20 2010, 09:28 AM Post #4 |
I don't know the mileage nobody knows how many times the odometer has rolled over but I will check compression and report back in a few days thanks |
| Memphis metro | Jun 20 2010, 10:26 AM Post #5 |
Lack of power could be a clogged converter, intake restriction, timing off, just to name a few or if you replaced the ecm, wrong ecm for the car. Or ecm needs driving cycles to retrain. . Edited by Memphis metro, Jun 20 2010, 10:31 AM.
7:14 PM Jul 10
