cooling fan; will not turn on when engine reaches temp
Topic Started: Jun 22 2010, 06:54 PM (3,880 Views)
iamgeo
Big League
Clocking?
CityConnection
Sir, yes sir!
I remember that at one point I was amazed by the number of temp sensors on a 3cyl Metro. I can't recall the year but there were 3 sensors on this car. 1 for the gauge, 1 for the ecu and 1 for the fan switch. Is it possible that the sensor you replaced is for the ECU and not the actual fan switch?
Also the easiest thing is to trace the power back from the fan motor and find where it stops. You could also check the sensors by measuring the values when you dunk them into boiling water.
Some have a fourth one for the A/C.
redpepe
if you're changing pistons, head, etc. you're already correcting what i suspect was the problem. it sounds like a blown head gasket to me. you've done all the right tests and corrections as far as i can tell .... hope you did a compression check. it also could have been a blockage of the coolant system but i think that is very rare. old rad hoses can collapse and restrict flow occasionally. i might have tried looking for coolant loss by bypassing fan switch and 'manually' running the fan ... then using as normal for a while if it stayed in its usual temp range.
the fan comes on around 212 degrees as i understand ... if everything else is working properly.
Fireball 89
hotdiesel80
Jun 22 2010, 07:23 PM
no power to rely ,so i jumped the relay and the fan went on , dis connect the fan and direct power the fan whent on , changed relays and jumped and fan went on ? next?
Hi hotdiesel80-
I'm with Mr Murf 59, I'd trace back through your system from the relay that works back through the wiring harness, to the switch, to the fuses, to the battery. Keep in mind a relay is an electric switch so you'll also have to trace the switched power back through the wiring harness, to the fuses, to the battery.
Edward
Edited by Fireball 89, Jun 23 2010, 07:50 AM.
hotdiesel80
ok thanks for all the help , i'll try all these things out , this weekend will finnish the engine rebuild
