Valve Cover Gromets
Topic Started: Jun 24 2010, 02:13 PM (914 Views)
slander
Tech Certified
Ordered an engine kit with a "valve cover gasket kit" included, didn't come with the gromets! Anyone know where these can be ordered WITHOUT getting another valve cover gasket?
JellyBeanDriver
Rock auto has them as a beck arnley part
BECK/ARNLEY Part # 0396425
Napa online shows them too, pn ATM KJ3601
I said screw them on mine and put a washer on them and silicon. Works for me.
I did something similar. I used a copper washer that fit inside the relief for the nut. The hole was just big enough to go over the stud. Then I put a small Oring on top of that and then another copper washer. Then the nut on the hole works. It did not leak a drop. And was much easier to get back apart. But you need to keep spare orings handy. As they can only be used once. This did work really well
That was kinda my deal too there Murf. I wanted something easier to take back off should the need arise.
slander
Tech Certified
I spoke with Bruce @ PartsDinosaur.com (Cool guy!) and he informed me that another Metro guy told him that a size 0 faucet washer works great as a replacement. I might have to give that a shot!
Learn something new every day.
KY Metro
I had some metal roofing screws that came with little padded washers....perfect fit. :thumb
slander
Tech Certified
KY Metro
Jun 24 2010, 08:11 PM
That's exactly what I ended up doing too. I actually glued them to a washer with arrow fletching glue and painted them. Nobody will ever know the difference!
