The Ratios Thread
Topic Started: Jul 5 2010, 01:35 PM (11,562 Views)
The table is meant to be used to calculate RPMs easily. If your car has a 4.10 and it spins 3,000 RPMs at 60mph and you want to know what it would spin with a 4.39 simply find the number (1.07 in this case) and multiply it by current RPM. 3,000*1.07 = 3,210 RPMs at the given speed.
The original post for this has been hidden in the spoiler tag below.
Spoiler: click to toggle
Attached to this post:
Attachments: Capture.jpg (33.01 KB)
Attachments: Capture2.jpg (30.21 KB)
Attachments: Capture3.jpg (30.54 KB)
Edited by Coche Blanco, May 6 2018, 08:41 AM.
Good bye
Very good, keep going. :)
This will help us all make decisions about tires and gears, since 3.52s are rare and 3.79s are very available. What size 13s do we need to buy to equal 3.52s. I already have 3.79s and 175/70-13s on my 91.
Thanks
Andy
Good start on the thread CB .
I'm going to sleep. I'd like some good criticism on this when I wake up. But be nice, it is 4 a.m. here.
Nicely done, this will be helpful indeed.
Here's your criticism, but it's minor quibbles and typos:
Up top, you should lose the 89-94 from this title - "Gear ratios for 1989-1994 US Swift/Metro 5-speed:"
Next paragraph, titled "Final drives", you should lose the wheel/tire size.
I was going to suggest four or five other names the car was sold as, but we are talking about North America, you probably chose best.
In the first sentence of "Tires General" you say "A popular replacement size is 144/80/12," you mean 155/80-12, simple typo.
Edited by Woodie, Jul 6 2010, 06:53 AM.
OH MY GOD!!!!!!! I nearly deleted the whole post...lmao
Thanks Woodie, that's what I needed. A fresh set of eyes. I've got to reword that last paragraph to make it a little easier to understand.
mjspiess
I think this fits in "The Ratio Thread" as well... I made this table for people who want to run different rims/tires, but would like speedo/odo stock or as close to stock as possible. Again, not all these tires exist or even fit the Metro, but in a perfect world would give you the closest OEM results. The combos in BOLD are dead on combos that will keep your speedo/odo reading correctly.
I'd like someone to tell me what's the max size tire you can run on a stock height Metro...
KY Metro
You could make this much simpler. I am not good at explanations, but I think the whole revs/mile thing is unnecessary.
Look at your example. You have a 4.10 and you want a 3.79, right? Divide it out:
4.10 / 3.79 = 1.08 (108%, or 8% 'longer legs' on the XFI). So you need an 8% taller tire.
since your tire is 21.1" tall, you need to go to 22.8". That just happens to be the standard height OEM for 95+Metros.
Look at the Rims n Tires Calculator.
Punch in your starting tire on one side, and play around with the second tire. It does most of the work, as it has the diameter, revs/mile, %faster, etc.
Edited by KY Metro, Jul 6 2010, 11:47 AM.
KY Metro
BTW, for the 95+ to get XFI gearing just from the tires, 4.39 / 3.79 = 1.16, or 116%. So you would need tires 16% over 22.8", which would be 26.4" diameter. Thats a tall tire.
The closest I can find in production is a 165/80 r15, which is 25.4", or 11.6% taller. Effectively lowers the ratio to 3.93.
I had gotten my mind wrapped around revs/mile for the RPM part of the question, and I forgot to "shift gears" and do it the easy way.
I see about 3 threads asking for information i've covered here. BUMP BUMP BUMP
I bookmarked this a while ago and use it quite frequently, thanks :thumb
One of the things to consider is the 3.52s are gonna be hard for a 3cly to pull. I think your gonna have to keep your foot in it really hard to get anywhere. I am not good with #s. I never have been. If you go to the tallest gears. Make sure you use a tire combo that will allow you to use this ratio. Neat thread CB.
undgsx-R
Self Certified Garage Mechanic
What happened to the original post? Its not much good now.
