| P0340 on a geo metro 97 LSI; P0340 on a geo metro 97 LSI | |
| Tweet Topic Started: Jul 7 2010, 07:26 PM (1,839 Views) | |
| Roberto_OSEGUEDA | Jul 7 2010, 07:26 PM Post #1 |
mi car its having problems to start, and isnt injecting fuel at all at the time that im trying to start it, check engine light its on and code that comes on the computer is P0340.... what can i do to fix it? |
| Bill CNC | Jul 7 2010, 08:14 PM Post #2 |
Hello Roberto, Welcome to the forum, ... The code you are quoting is; P0340 CAMSHAFT POSITION SENSOR CIRCUIT MALFUNCTION |
| Johnny Mullet | Jul 7 2010, 08:34 PM Post #3 |
You need to test if the Distributor is putting out a signal and test if the crank sensor is putting out a signal. Do this with a DVOM set on AC voltage low setting. |
| Roberto_OSEGUEDA | Jul 8 2010, 10:35 PM Post #4 |
ok thanks im going to check that, and that the reason my car dont wanna start and why? |
| Bad Bent | Jul 8 2010, 11:28 PM Post #5 |
Welcome to the forum, Roberto_OSEGUEDA ! Check out Testing CMP sensor. May want to look at www.obd-codes.com/p0340 also, for further suggestions, like the crankshaft position sensor which won't work if the oil pan has a cork gasket. |
9:33 AM Jul 11
