| More on Brakes | |
| Tweet Topic Started: Jul 16 2010, 06:22 PM (724 Views) | |
| JohnyP | Jul 16 2010, 06:22 PM Post #1 |
Hey guys, Just a quick question. It seems that when coming to a stop if i drop down into Natural that i can stop much faster then if I stay in whatever gear I am in. Is this normal and does this in anyway hurt the tranny or brake system? All the best JohnyP |
| Rooy | Jul 16 2010, 06:34 PM Post #2 |
That doesn't seem normal. Are you saying that the brakes themselves seem more effective when not in gear? I really don't know what to make of that if that's the case. Keeping it in gear should give some "engine braking" and help slow you down. |
| JohnyP | Jul 16 2010, 06:45 PM Post #3 |
Yeah Rooy, That is what I am saying. It does seem that the brakes are more effecting when not in Gear. I thought that this seemed odd. I dont really know if it is a bad thing though as the brakes work well in gear as well but is seems that if need I could drop into N and stop on a dime..... |
| DesmondGhostRider | Jul 16 2010, 08:31 PM Post #4 |
hmm...maybe you break hard and when you do the engine is fighting to stay alive? But when your in natural or neutral the engine can just run so no bogging down. Maybe bogging can affect the brake booster (do geos even have brake boosters?) |
| nerys | Jul 16 2010, 09:23 PM Post #5 |
Grr
yes this makes sense. the engine is trying to make you go FORWARD this will counter some of your attempt to slow down. SO in neutral there is no forward force but inertia so the brakes will seem to work better. but this is odd since the effect is so small you should not be able to feel or sense the difference. |
| Rooy | Jul 17 2010, 03:08 AM Post #6 |
In gear above idle the engine will slow you down, not speed you up. This is called engine braking. |
7:44 PM Jul 10
