Tire Size Suggestion; Tire Size
Topic Started: Jul 27 2010, 01:40 PM (821 Views)
DRDrayton
I do not believe I have ever had a decent set of tires for my Geo until today. First of all good luck find a decent set of tires in the original 155/80R-13 spec, they are just not available. However changing to the tire size to 175/70R-13 some good options come in to play such as the Pirelli Cinturato P5, an 85,000 mile tire for just $50 at Discount Tire which I purchased today.
The Speedometer will be within 1/2 a mph at 65mph so nothing to worry about there. The steering and roll-ability of the car increased dramatically. Do your self a favor the next set of tires, move up to 175/70-13s, you'll be glad you did.
CityConnection
Sir, yes sir!
Yup. I installed 175/70R13 Falken tires on my 2000 and the ride and handling is great compared to the 155s.
I have a 93 (OEM is 145/80/12) and I have 155/80/13's on it and will be moving to 175's when I need new tires. I don't know how people ride on 145s...
I'm with you there CB, they scared me to death. Now that I know what it's like to be able to stop, I could never go back.
Jul 29 2010, 06:07 AM
I still can't stop, I have 12" brakes. haha
t3ragtop
you know the fix for that, don't you?
a trip to the junkyard to rob parts from a 95 up or a vert. just pull the whole assembly, breaking the knuckles off the ball joints and pulling the 2 bolts out of the strut mount for the fronts. pop the axles and brake hoses and run away with the lumps. :D
take the rear drums for the 12mm wheel studs and 13" rims will fit on all 4 axles.
you get all the benefits - improved braking with ventilated rotors on the front, easier brake jobs with the rotor over hub design, and stronger wheel studs and lug nutz.
:gp
If Christine did not get fixed, I was going to do this for my 92 XFi :thumb
