| bumper and fenders | |
| Tweet Topic Started: Sep 8 2010, 10:05 AM (1,561 Views) | |
| mlongkc | Sep 8 2010, 10:05 AM Post #1 |
member
Will 94 metro hatch bumpers and fenders interchange with a 92 vert? Is there anywhere on here telling how to go about taking off and replacing these? |
| bogs | Sep 8 2010, 11:03 AM Post #2 |
Not sure about the first part of your question, although I'm pretty sure they are interchangeable. How do you remove the fender?![]() 1. Disconnect the negative battery cable. 2. Remove the parking lamp and slide away from fender. Disconnect bulb socket. 3. Raise and support the vehicle safely. 4. Remove tire and wheel. 5. Remove wheel housing. 6. Remove antenna from right fender, as required. 7. Remove fender bolts at door pillar. 8. Remove inner fender bolt. 9. Remove upper fender bolts. 10. Remove support nut securing fender to bumper fascia. 11. Remove retaining bolt from fender brace. 12. Slide fender off bumper side slider and remove. To install: Slide fender on bumper side slider and install. Install retaining bolt on fender brace. Tighten to 15 ft. lbs. (20 Nm). Install support nut securing fender to bumper fascia. Tighten to 15 ft. lbs. (20 Nm). Install upper fender bolts. Tighten to 15 ft. lbs. (20 Nm). Install inner fender bolt. Tighten to 15 ft. lbs. (20 Nm). Install fender bolts at door pillar. Tighten to 15 ft. lbs. (20 Nm). Install antenna on right fender, as required. |
| mlongkc | Sep 8 2010, 01:57 PM Post #3 |
member
Thanks Bogs |
| bogs | Sep 9 2010, 03:27 AM Post #4 |
No problems If you are ever in a pinch for information, you might find it in a link Jittney posted http://www.powerlibrary.net/Remote/Remote.asp?ID=meadville and insert the password pl2494xxxxxxxx Its not (anywhere near) as good as a factory manual, but it is I think a chiltons or clone style. |
| Woodie | Sep 9 2010, 07:13 AM Post #5 |
Yes, the only difference is the antenna hole. |
| mlongkc | Sep 9 2010, 07:35 AM Post #6 |
member
Thanks guys, the reason i ask is i just bought a parts car(94 2 dr) and everything i need for 92 vert it has plus it is complete with motor and transmission. Well i'm still looking for a drivers side door. |
9:15 AM Jul 11
