Tool advice needed
Topic Started: Oct 1 2010, 03:36 PM (696 Views)
superduty5.9
Metro Defender
I asked this already but what is your opinion on this tool. It's $52. Ebay Posted ImageI don't use it often but when I do it gets a workout so I want a quality one. I also am on a budget so $ is an issue. The cheap $20 ones at advance, autozone, o'reilly don't last long. The little 3/16 die always breaks off in the tube. The Blue Point one I used before worked fine but is still the same design as the cheap ones. I have seen these ratching type before but never used them and there is one similar on ebay for $200. Does anybody use these or similar? Do Mac or Matco have anything good?
I have not tried one like that before. I have always used to spring style. It just slides over the tubing to be bent, and then you pull in the shape you need.
superduty5.9
Metro Defender
This is a double/single flaring tool Mr Murf. It's not a tubing bender.
Good bye
I have found the trick to not breaking the mandrel is grinding a taper on the end of the tubing. All kits no matter what brand seem to have the same issues with breaking the guide pin off. The taper seems to help, I have not broken mine since I started grinding the tubing.
Rooy
I have it, and it works well. I posted in your other thread here: http://geometroforum.com/topic/3826304
I do put a chamfer on the outside of the tube and de-burr the inside before flaring.
Robertwb70
That's the only type I use now, it's MUCH easier to use in tight spaces so you don't usually have to disassemble everything to get it done.
superduty5.9
Metro Defender
me and my metro, thanks I'll try the taper trick. :banana
Robertwb70 and Rooy thanks, I think I'll get one now. :cheers
Mr Murf 59
Oct 1 2010, 03:39 PM
My mistake, Sorry brother. :smackface
superduty5.9
Metro Defender
not a problem. In the pic it's hard to tell.
