| where can I order a new inside door latch? | |
| Tweet Topic Started: Oct 9 2010, 07:45 PM (961 Views) | |
| Metroic | Oct 9 2010, 07:45 PM Post #1 |
where can I order a new inside door latch? for a 1989 metro? they all get stripped from junkyards in 4 hours after listing on Pick and Pull. I'm talking aobut the inside plastic drivers side door release that breaks real easy. |
| slander | Oct 9 2010, 08:05 PM Post #2 |
Tech Certified
I see them from ebay from time to time. One of these days I'll make a video of how to fix them. Some might think it's a little redneck, but it's stronger than new, and you'll never notice a difference. |
| iceman | Oct 9 2010, 10:52 PM Post #3 |
Try vehiclepartsunlimited.com I bought a inside door handle for My 1993 Metro for $22.99 total price including U.S.P.S. shipping. |
| Jittney | Oct 9 2010, 11:12 PM Post #4 |
fix your own? Mine broke this spring. I 'fixed' it with a long thin bolt and nut. There were 2 things broken. The plastic pin at almost the top and the bottom plastic hole that the pin slides into. It was a matter of finding a replacement for the pin.... and then having it long enough to brace against something else. After I took this picture, I thread the top part farther down... and placed the nut between the bottom two broken holes. I carved out a niche on the bottom of the plastic cover and the cover fits on.
| idmetro | Oct 10 2010, 07:57 AM Post #5 |
If you really want a new one you could try here http://www.suzukicarparts.com/partlocator/index.cfm?siteid=214820 they are set up just for Suzuki parts (your will need to tell the system you want parts for a Swift), you will likely have to dig around to find what you want, for instance door handles are under (Front door/Glass and Hardware/Door handle/Inside) and finally they are not cheap, an inside door handle is ~$60. But if you've just got to have one this may be the way to get one as many of the Swift parts will swap across, I am not sure but would think the door handles would too. |
| Joebafett | Oct 10 2010, 09:08 AM Post #6 |
I found that the pick-a-part / wrench-a-part yards are an excellent source for spare bits. In my case some of the parts interior wise had similar matching geo rot patterns |
9:15 AM Jul 11
