| Geo Metro top replacement | |
| Tweet Topic Started: Oct 23 2010, 08:57 PM (2,215 Views) | |
| yoshiki2 | Oct 23 2010, 08:57 PM Post #1 |
I've been checking metros and i just discovered that there are some convertibles. from what year to what year can i get them? are there top replacements? any parts hard to find? How big is the trunk? Any things I should look for before buying it? thx 4 the answer Edited by yoshiki2, Oct 23 2010, 09:01 PM.
| idmetro | Oct 23 2010, 09:04 PM Post #2 |
Indeed there are convertibles. I believe they were produced from 90-93. Replacement tops are available as are most parts with the notable exceptions of the weatherstriping and the tonneau type cover for the top when it is in the down position. No doubt there are other unique parts but many of the parts are shared with the hatchbacks of the 89-94 generation. |
| yoshiki2 | Oct 23 2010, 09:06 PM Post #3 |
a friend just told me that the a/c escapes from the car thru the windows, or something like that |
| mcmancuso | Oct 23 2010, 09:07 PM Post #4 |
Trunk space is surprisingly adequate, a big note, the convertible is a 2 seater. Door to top seals are almost impossible to get. Everything from below the windows is same as 2 door hatch. |
| yoshiki2 | Oct 23 2010, 09:16 PM Post #5 |
is the trunk as big as my 99 metro 4 door lsi? How much should i pay for it, and how much will usually cost me to rebuild the engine ( a 3 cyl must be in bad shape by now) |
| zcrayfish | Oct 23 2010, 09:55 PM Post #6 |
Chatroom Addict...
Just curious, but are any of the weatherstripping components folks have been looking for available on gmpartsshop.com ? ![]() 4 through 9 is available... Part # 2 in the diagram is the one I can't find anywhere, is that the one causing trouble for everyone? |
| geogonfa | Oct 23 2010, 10:08 PM Post #7 |
gmpartsshop.com states they have them, until you order them... |
| zcrayfish | Oct 23 2010, 10:10 PM Post #8 |
Chatroom Addict...
Well that's pretty lame.
| easymoney1412 | Oct 23 2010, 11:36 PM Post #9 |
I bought a 1992 convertible with 71,000 miles on it for $1400.00 in August of this year in Orlando, there were a couple others with a/c and without for $1400.00 to $3000.00, most had more miles then the one I bought. |
| idmetro | Oct 24 2010, 07:12 AM Post #10 |
These cars have 5 digit odometers so without other supporting documentation I would lean toward 171k miles rather than the displayed 71k miles. a/c adds a significant power drain (very noticeable when driving) and will cost 5-7 mpg on a car with a manual transmission, consequently I use my a/c rarely. On the fun-o-meter I believe the manual transmission cars rank orders of magnitude above the automatic equipped cars. Good Luck on your search. |
| easymoney1412 | Oct 24 2010, 11:54 AM Post #11 |
Being as how you don't have the documentation that I have I can understand how you might question the mileage, especially if I was trying to sell you the vehicle. That is not the case so it is not relative. The only reason I mentioned it here was Yoshiki2 was thinking that a 3 cyl would be in pretty bad shape being that old, it all depends on how it was maintained and how many miles it has on it. Or in my case how long it was stored and what kind of conditions it was stored under |
| easymoney1412 | Oct 24 2010, 11:57 AM Post #12 |
By the way mine and all the other convertibles I mentioned were on Craigs list in Tampa and Orlando |
| mcmancuso | Oct 24 2010, 01:39 PM Post #13 |
Think of the trunk as being what a regular metro is up to the top of the back seats, its not going to be as big as a hatchback because its got a trunk lid, bot the width and length are pretty much the same.
| bogs | Oct 25 2010, 02:40 AM Post #14 |
He was asking in comparison to a 4 door 99, which I am pretty sure is only available as a sedan, similar to my 96 instead of a hatch back. |
9:14 AM Jul 11
