Replacing door pins/bushings; How To
Topic Started: Nov 14 2010, 11:08 PM (6,888 Views)
A lot of us have a Geo Metro with sagging doors. The problem is that nobody makes these replacement door hinge and bushing kits for the Metro. From the info learned on this board, I found out door pin kits for a 1991 Nissan Pathfinder work perfectly in 1989-1994 models. Not sure if 95-2001 models have the same pins. I started by removing the pin from the door stop..........
Now use a pick to remove the "e" clips from the original pins.............
Use an assistant or a floor jack to keep the door level for the next steps...........
Using various screwdrivers, punches, and hammers, drive the old pins out of the bushings taking note of the stress on the door. This may take some persuasion getting them out..........
Once the pins are out, the door can be dropped. You can unplug the wiring or leave it intact if you have room...........
Remove the old bushings with a hammer and screwdriver.............
Carefully install the new bushings supplied in the kit (2 kits per door) and make sure they seat.........
Get the door lined back up and install the new pins. The replacement pins are much longer, but still work well for this application............
No more slamming the door shut :thumb
Nice write up :thumb
undgsx-R
Self Certified Garage Mechanic
Excellent!
Interesting. :hmm I was going to unbolt the hinge from the door to gain access to the pin.
Did you have help? Or do it by yourself? (I need to fly solo most of the time)
I did it by myself, but ended up dropping the door once :smackface
I highly suggest a helper to remove and re-install the door.
metro-mike
Will this work on all Metro's. Thanks.......
I am not 100% sure if the 1995+ models has the same pins.
You got that part number for the bushings? If I can run it down I will see if they will work on my 95.
snowfish, you can make a helper out of 2x4's. This is how we used to support doors and things when I worked in carpentry. Build at least 4 L shaped pieces , as pictured below:
Set them together the way the picture shows, adjust them to the width of the object your trying to hold upright, then clamp them together. Don't be stingy on the length of the leg on the floor, as this is what provides your lateral steadiness.
In the case of the car door, either use the floor jack to hold it height wise, or screw 2 scraps to the uprights at door level, and your good to go :)
mcmancuso
Ask for '92 pathfinder pins, its a doorman product, most auto places have them in stock. It does work in the later body style as well. I put a set in my 99 4 door.
Spock
Live Long and Prosper.
Very cool post, JM
Thank you!
Napas part number and cost is less than 8 dollars.
Rooy
Also Dorman 38397.
They appear to have gone way up in price. $14 at AutoZone and $10 at Advance Auto.
They used to be $5 at Advance just a couple months ago.
I got mine from RockAuto. They're currently $3.98 each. $2.66 to ship four of them to me.
Potter
Col. Potter
boy i wish who ever owned Taylor would have seen this... they took the hinge off and welded it where they wanted it... it shuts straight...just REALLY tight gap up front.
Good write up.. ill keep this in mind in case Sophias ever go bad... oh and thanks engine doc for the Part Number
econoboxer
I am the one on the left.
recommendations being taken for replacing lower LH door hinge, not the pin, as the metal has elongated... thanks
