Back window removal/install; who has done it?
Topic Started: Nov 26 2010, 05:45 PM (565 Views)
Barton
I need to switch the hatch glass on my 96 and I would like to know if I'm better off just swaping the hatches or if I can change the glass easy enough. :hmm
Good bye
I changed the whole hatch. Changing just the glass is like changing a windshield. The first trick is removing the glass without breaking it. If you can get a wrecking yard to remove one then I would just change the glass. Getting the surrounding trim pieces to fit back in is difficult, maybe just urethane to the top and smooth it out.
