Engine diagnostic circuit 92 Metro; Check engine light will not flash codes
Topic Started: Dec 5 2010, 05:14 PM (1,425 Views)
Bill Parisian
I just bought a 92 Metro that was running poorly. I new it was a valve/cam problem before I bought it. The CHECK ENGINE LIGHT was not on. I changed the head, runs better, still no check engine light. I cleaned the throttle body coolant port and changed the sensor, Runs better no more smoking/flooding out, changed air charge sensor, not much change. I tried to check diagnostic codes and the check engine light comes on but no flashes. Any Idea what to do? :'(
MR Bill
Welcome to the forum
Bill
GeoStalker
If there's nothing wrong, you should be getting a one dash pause two dash signal (1-2). That means all clear. Did you put an extra fuse in the spare port in the fuse box?
Bill Parisian
No I didn't know about putting a fuse in, can you leave it in or do you take it out after diagnostics?
I know it should read code 12 if everything is ok but I am new to this diagnostics I am old school give me a 62 Nova 4 cyl any day.
Jittney
Take the fuse out after testing and put it back on the side with the other spares. :)
Bill Parisian
Ok that worked but all I get is code 12. My problems are still there they are posted on the diagnostics page.
liszabailey
Hi have you check the fuse if they are properly connected :gamerz and did you check all of the geo metro parts? have tried asking it on where did you bought it?.... :hmm :hmm :hmm :hmm
Edited by liszabailey, Dec 16 2010, 02:10 AM.
