| Need Help ASAP; Convertible Bearing Seal? | |
| Tweet Topic Started: Jan 20 2011, 11:14 AM (1,166 Views) | |
| jonathan180iq | Jan 20 2011, 11:14 AM Post #1 |
Not Really All That Smart
I dropped my car off with a guy to press in my new bearings. (Verts have the fat one piece) He's telling me there is an issue with the seals on the Verts not having a seal up there and he can't put the hubs back on the car without destroying them and I'm tying up his only lift... I thought the Vert bearings were self sealed and didn't require anything else. I wouldn't feel bad about this, but I bought the parts and told him I had everything so he agreed to jump on it first thing today while I was at work. Is there something I am over looking here? He's trying to find one locally and I'm not having any luck on any of the parts places that I can find in the local area. I don't want to shut down his shop for a day because of stupid seals... |
| jonathan180iq | Jan 20 2011, 02:46 PM Post #2 |
Found the part. Thanks for all the responses...
| jonathan180iq | Jan 21 2011, 08:51 AM Post #3 |
For what it's worth, the Verts have a grease seal on the inside of the hub to protect the already sealed bearing from getting nasty slop slung all over it. I don't remember ever seeing that mentioned so there it is. ![]() I don't have a [art number but they are roughly $15 per seal. EDIT: If you aren't in a bind that causes you to need them in less than 1 day, then you can get Convertible (also MKI Turbo) bearing seals for about $6 at Rockauto.com - Beck/Arnley Part #0523461 (credit: Pacapo) Since this is the same bearing as the 95+ Metros, I'm assuming that newer models can use this information as well. Edited by jonathan180iq, Jan 21 2011, 12:15 PM.
| billy508 | Jan 21 2011, 11:55 AM Post #4 |
billy508
Sorry I could not be of help but I have never replaced mine. Thanks for the info. I will know what to do if I ever have to. I dont think we were ignoring you. We know almost everything thing but not everything. Verts, as you have found out, have a few diffident things that make them unique .
Edited by billy508, Jan 21 2011, 12:01 PM.
| jonathan180iq | Jan 21 2011, 12:17 PM Post #5 |
I know I wasn't being ignored. I was just in a situation where I needed clarification lickity-split and it wasn't able to happen like that. Like I mentioned above, everything is all good now. Installed and rolling smoothly again. |
| billy508 | Jan 21 2011, 02:32 PM Post #6 |
billy508
Very good. Thanks for the report. Glad you are rolling again. I dont know part of Georgia you are in, but you are more than welcome to come to the Geos On the Gulf April 16th.
Edited by billy508, Jan 21 2011, 02:36 PM.
| jonathan180iq | Jan 21 2011, 04:52 PM Post #7 |
What part of the Gulf? I'm in the N GA Mountains... Dalton |
| billy508 | Jan 21 2011, 05:26 PM Post #8 |
billy508
We are planning of April 16 a one day event at Gulf Shores Alabama . We are panning of meeting at the Alabama state fishing pier but that might change if the venue gets too big. But it will be fun. read more on the front page
| easymoney1412 | Jan 21 2011, 06:26 PM Post #9 |
I must have missed something, what happened to the Big Lagoon State Park? |
| easymoney1412 | Jan 21 2011, 06:31 PM Post #10 |
Hey Jonathan, are these the frony bearings you replaced or all four? |
| jonathan180iq | Jan 21 2011, 07:23 PM Post #11 |
Easy, if there is supposed to be a photo there then I don't see it. For the Convertibles, MKI Turbos and 95+ cars, there are not 4 bearings up front (2 per side). There are only two fat bearings (1 per side) that must be pressed in with a machine shop press. I know I've read that the base model Metros, with their 2 bearings per side, can be knocked out by hand. This is not the case with the Verts and others mentioned. Base model Metros, 89-94, use bearings like the first picture. Verts and others use the fat bearing pictured below that: ![]() ![]() And, as I have mentioned previously, there is also a grease seal on the inside of the Vert-etal bearings that I did not know was necessary. The 89-94 base model Metros have one seal per side of the hub... (1 seal per bearing = 4 seals & 4 bearings) Credit again to Pacapo for this diagram showing the Vert/Turbo hub. #5 is the seal I did not know about. (This diagram does not apply to base model Metros...
Edited by jonathan180iq, Jan 21 2011, 07:31 PM.
| easymoney1412 | Jan 22 2011, 12:29 AM Post #12 |
Thanks Jonathan, I didn't state that very good, although what you pictured here is cool. I hadn't even got around to looking at bearings so I didn't even realize the verts were different then the others. I was wondering if you were replacing bearings on all four axles. Were you having problems or just replacing them because of high miles? |
| jonathan180iq | Jan 22 2011, 01:02 AM Post #13 |
Ohhhhhhhh.... I had a bad driver's side front bearing so I changed out both of them. It was also time for a new passenger side Cv axle so I swapped in re-manufactured front axles at the same time. Now I have a new, free rolling front end. I think I still need an alignment as it's pulling to the right a little bit it's pretty good now. Ready for another 150,000 miles. |
7:44 PM Jul 10
