Rear brake cylinders sedan; 5/8" or 11/16"
Topic Started: Jan 23 2011, 09:48 PM (734 Views)
tirebiter
1997 Geo Metro sedan, 4-door with 4 cylinder and 3-speed automatic transmission. Rear brake cylinder is 11/16" but I broke off the bleeder. Does the 5/8" cylinder bleeder fit ? What would happen if I put in two 5/8" cylinders ? Why do all the pictures at online parts suppliers look different than what I have ?
HELP !
Online suppliers usually show a generic picture. Just get what you need at your local store and they will help you out.
JellyBeanDriver
Put the same size ones in that came out.
Edited by JellyBeanDriver, Jan 23 2011, 11:25 PM.
rcdraco
The 5/8ths will not work properly, the 4 door has larger wheel cylinders because the shoes and drums are also larger, I assume to compensate for slightly higher weight. The Bleeders _may_ be the same, a reputable parts store should be able to get good bleeders for you. I know the fronts are uncommon, the rears were listed as a regular 10mm at work, but I don't know if the 4 door is different at all.
