| play in front wheels, but not in rear?; loose wheels | |
| Tweet Topic Started: Jan 31 2011, 03:17 PM (800 Views) | |
| Metroic | Jan 31 2011, 03:17 PM Post #1 |
I got play in front wheels, but not in rear? Is that how it is supposed to be, because of different types of bearings.... the fronts being twin ball races and the rear being beveled rollers under torque? |
| bansheetaz | Jan 31 2011, 03:31 PM Post #2 |
you shouldnt have bearing play in your front wheels. |
| Johnny Mullet | Jan 31 2011, 03:36 PM Post #3 |
Is it bearing or maybe a tie rod or ball joint? |
| Bad Bent | Jan 31 2011, 06:45 PM Post #4 |
How have you tested the play? You might jack up the front end and grab the wheel at 9 and 3 o'clock and see if there is any play. You can grab the tie rods and see if there is movement. Then grab the wheel at 12 and 6 o'clock and pull in and push out. There should not be any clicking or movement. Spin the wheel to see if it rotates freely. Here is a good one...
| Rooy | Jan 31 2011, 07:45 PM Post #5 |
Front and rear bearings are of the same type (single row ball bearings with a spacer in-between), and neither should have any play. Another thing to check is that the spindle nuts are tight. |
7:44 PM Jul 10
